correct intake for engine?? #652309
03/26/10 10:59 PM
03/26/10 10:59 PM
Oh
His and Her 69's Offline OP
Oh
I have a 70 bee 383 4 bbl, auto, etc and I need to know if any of these intakes would be correct enough to use for my car??
My original engine is dated 8-26-69,
the stamped pad by the dist has - F 383, 3 11, hp
on it.
One question is would a 69 intake be correct #2806301 since the casting date on the block is 8-26-69?? or do I need a 70 intake # 2951666 ???
Question #2 my #2951666-1 what does the -1 mean???
and the last question, I have 2 intakes with #2951666 on them and one has a date code of 5.3.9 I assume this one is May 3rd 1969 and the other is 5.02 what are these dates as I can't find the info in my galen white book.
Any Help on these questions would Help me out Greatly. If neither intake is close for my car let me know Please.
Thanks David
Re: correct intake for engine?? [Re: His and Her 69's] #652310
03/27/10 01:32 PM
03/27/10 01:32 PM
michigan
70 buzz Offline
70 buzz  Offline
michigan
I would say the 2951666 is correct
Re: correct intake for engine?? [Re: 70 buzz] #652311
03/28/10 02:13 AM
03/28/10 02:13 AM
Oh
Oh
Can anyone else HELP answer any of my questions???
I have a friend that needs 1 of the intakes for his 71 satellite but I would like to keep the one that fits my car close to the Correct date.
Anyone know what the -1 behind the 666 number mean???
Please Help me figure this out.
Thanks David
Re: correct intake for engine?? [Re: His and Her 69's] #652312
03/28/10 08:16 AM
03/28/10 08:16 AM
michigan
70 buzz Offline
70 buzz  Offline
michigan
Go to mymopar and check the reference portion. You may find what you are looking for there
Re: correct intake for engine?? [Re: 70 buzz] #652313
03/28/10 09:50 AM
03/28/10 09:50 AM
MO
cdp Offline
cdp  Offline
MO
the -1 is probably the core #. Since they are sand cast molds, there are more than 1 mold, or, there are more than 1 cavity per mold.
I also think the 666 casting would be correct. 301'sre 68/69.
A friend has a 5k mile original Bee, I can look at his intake today. He's just few blocks away. Don't know the build date, but I know its a St. Louis plant car.
Re: correct intake for engine?? [Re: cdp] #652314
03/29/10 02:42 AM
03/29/10 02:42 AM
Oh
Oh
If you get the time to look at your friends bee that would be Great.
My VIN starts in the 0A211--- and with a number in that range My motor must have been sitting awhile. 8-26-69 cast date with a 3-11 assembly date??
I Appreciate the link and Assistance.
David
Re: correct intake for engine?? [Re: His and Her 69's] #652315
03/29/10 09:42 AM
03/29/10 09:42 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Thanks David
My best guess
Yes you need a 1970 style intake - 69 and 70 take different style chokes
2951666 is correct style 1970 intake
I belive the 1 means core # or core revision
Intakes usually have a 5 digit date code on them , as an example 05039 = May 3rd 1969
so I'm going to leave that one open but my guess is neither is right for your car
Re: correct intake for engine?? [Re: gtx6970] #652316
03/29/10 10:05 AM
03/29/10 10:05 AM
30 Rock
JS29 Offline
JS29  Offline
30 Rock
Re: correct intake for engine?? [Re: JS29] #652317
03/29/10 11:20 AM
03/29/10 11:20 AM
michigan
70 buzz Offline
70 buzz  Offline
michigan
my intake has the same number except it has -2 without a date code
Re: correct intake for engine?? [Re: 70 buzz] #652318
03/29/10 11:44 PM
03/29/10 11:44 PM
Oh
Oh
70 Buzz, What number are you talking about that has a -2??
The 2951666 number has a -2 behind it??
The date codes are on the bottom of the intake so I guess no one will see them except me.
Thanks Bill for the info.
I will use my 2951666-1 intake then. Thanks Guys
David
Re: correct intake for engine?? [Re: His and Her 69's] #652319
03/30/10 01:04 PM
03/30/10 01:04 PM
michigan
70 buzz Offline
70 buzz  Offline
michigan
David
my intake reads 2951666-2
