Re: Is there a way to keep compressor from cycling
[Re: 1Adam12]
#651960
03/26/10 03:34 PM
03/26/10 03:34 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
How rapidly is it cycling? If it's a real short cycle it's probably low on charge.
[Re: John_Kunkel]
#651961
03/26/10 03:39 PM
03/26/10 03:39 PM
Posts: 15,491 the boonies
aarcuda
the boonies
screwdriver thru the condensor works
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: stumpy]
#651963
03/26/10 10:57 PM
03/26/10 10:57 PM
DaytonaTurbo
Manitoba, Canada
Unplug the compressor until summer gets here.
Unplug the wire to the compressor clutch. However the dehumidified air from the a/c system sure does clear a foggy window a lot faster than regular air.
[Re: 1Adam12]
#651964
03/27/10 01:22 AM
03/27/10 01:22 AM
Posts: 704 USA
rftroy
USA
For the same reason, having the compressor off for defrost, I cut the wire to the compressor clutch and added wiring from the two ends to a switch in the dash. That way you can "turn off" the compressor and, with the flick of a switch, return everything to normal operation.
Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: rftroy]
#651965
03/27/10 09:04 AM
03/27/10 09:04 AM
RapidRobert
If it is a good idea to run the A/C for 5 minutes or so regularly (weekly?) to circulate the oil over the cold months I'd add a cutoff sw
[Re: RapidRobert]
#651966
03/27/10 12:21 PM
03/27/10 12:21 PM
DaytonaTurbo
Manitoba, Canada
Yes that is a good idea, the compressor seals supposedly need lube flow to keep them from drying out so it's a good idea to run the system periodically.
