340 Intake Question Please Help #649871
03/24/10 10:11 AM
03/24/10 10:11 AM
Boca Raton, Florida
daveh1971 Offline OP
Boca Raton, Florida
Hey guys,
I'm finishing up assembling my engine and I want to get a new intake. It's a mild 340, 30 over, purple cam, forged crank, 2.02 1.94 heads, Holley 750. Now I am changing the car over to a shaker car and I'm not sure what intake will fit better under the hood. I don't want the hood not being able to shut or be forced against the air cleaner. I want an aluminum intake for the weight difference. What intake should I use? Or what intake sits the lowest. I would rather put a spacer on than have one that's too tall. I want the one that's closest to stock so the hood will shut and will work best performance wise with my engine combo. I'm open to any suggestions if you don't like my examples below.
This is what I'm being told. What is your choice both the pros and cons. Thanks again
LD340
Weiand Stealth
Edelbrock Performer
Edelbrock Performer RPM
Rpm Air Gap
Re: 340 Intake Question Please Help [Re: daveh1971] #649872
03/24/10 10:15 AM
03/24/10 10:15 AM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
I always like LD340's if you can find one. But closest to stock intake is the Performer. It's also the cheapest and easiest to find of those.
I believe most of those come to the stock height though.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: 340 Intake Question Please Help [Re: MonGoo$e] #649873
03/24/10 04:10 PM
03/24/10 04:10 PM
Boca Raton, Florida
Boca Raton, Florida
No one else has any info on the subject? Anything I can get is greatly appreciated. I just don't want to spend the $$$$ and it be too tall. Thanks
Re: 340 Intake Question Please Help [Re: daveh1971] #649874
03/24/10 04:16 PM
03/24/10 04:16 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
purple cam Which purple cam as that's a generic name for mopar cams
LD340, Edelbrock Performer RPM, Rpm Air Gap All these are about the same, great intakes, IMHO
Weiand Stealth Good intake once you get the jetting quirks figured out
Edelbrock Performer I wouldn't use this one, I'd use a factory iron intake w/ a 1" spacer, before this intake.
There you go, some other input
As far as intake height and shaker, you'd need to measure the stock carb/intake height and figure out the max you can go. The LD, RPM, Air Gap and Stealth are all taller than the factory intakes, IIRC.
Re: 340 Intake Question Please Help [Re: RobX4406] #649875
03/24/10 04:58 PM
03/24/10 04:58 PM
Boca Raton, Florida
Boca Raton, Florida
Thanks I appreciate it.
Re: 340 Intake Question Please Help [Re: daveh1971] #649876
03/24/10 05:06 PM
03/24/10 05:06 PM
The SB street dominator intake is very low profile and can be bought regularly for $60-$75 but it does have 318 ports
Re: 340 Intake Question Please Help [Re: daveh1971] #649877
03/24/10 09:16 PM
03/24/10 09:16 PM
Oklahoma
smokkem Offline
smokkem  Offline
Oklahoma
i'm doing the same thing with a 360, using an eddy rpm airgap, definately the better intake for up to 6500-7000 and torque, stock intake height is around 4.5 to 5", rpm airgap is 5.35", so you would have to get a lowered air cleaner base(eddy or such)and fab it with a repro shaker base plate to lower the base plate about the same amount as you raise the intake, it can be done
Re: 340 Intake Question Please Help [Re: smokkem] #649878
03/25/10 02:35 PM
03/25/10 02:35 PM
P
Paul_Fancsali Offline
P
To fit use M-1 dual plane forget the standard performer they are for 318s. The others listed are all good use a LD if you can find one
Re: 340 Intake Question Please Help [Re: Paul_Fancsali] #649879
03/25/10 05:06 PM
03/25/10 05:06 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
you said 2.02 / 1.94 heads... as in 1.94" exhaust valves??? really? How'd you fit them?
I like the way the Stealth and RPM Air-Gap perform(ed) on my 360, so Id go with either of those then tackle making the air cleaner fit right to the hood afterwards. Good luck!
Re: 340 Intake Question Please Help [Re: Alikazam] #649880
03/25/10 05:16 PM
03/25/10 05:16 PM
scratchnfotraction Offline
LD340 hands down ditch the aircleaner for another
