Re: 340 Intake Question Please Help
[Re: MonGoo$e]
#649873
03/24/10 04:10 PM
03/24/10 04:10 PM
Posts: 51 Boca Raton, Florida
daveh1971
Boca Raton, Florida
No one else has any info on the subject? Anything I can get is greatly appreciated. I just don't want to spend the $$$$ and it be too tall. Thanks
[Re: daveh1971]
#649874
03/24/10 04:16 PM
03/24/10 04:16 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
purple cam Which purple cam as that's a generic name for mopar cams
LD340, Edelbrock Performer RPM, Rpm Air Gap All these are about the same, great intakes, IMHO Weiand Stealth Good intake once you get the jetting quirks figured out Edelbrock Performer I wouldn't use this one, I'd use a factory iron intake w/ a 1" spacer, before this intake.
There you go, some other input
As far as intake height and shaker, you'd need to measure the stock carb/intake height and figure out the max you can go. The LD, RPM, Air Gap and Stealth are all taller than the factory intakes, IIRC.
[Re: daveh1971]
#649876
03/24/10 05:06 PM
03/24/10 05:06 PM
RapidRobert
The SB street dominator intake is very low profile and can be bought regularly for $60-$75 but it does have 318 ports
[Re: Paul_Fancsali]
#649879
03/25/10 05:06 PM
03/25/10 05:06 PM
Posts: 571 Beaverton, OR, USA
Alikazam
super gas
super gas
Beaverton, OR, USA
you said 2.02 / 1.94 heads... as in 1.94" exhaust valves??? really? How'd you fit them? I like the way the Stealth and RPM Air-Gap perform(ed) on my 360, so Id go with either of those then tackle making the air cleaner fit right to the hood afterwards. Good luck!
