Studs or bolts for eddy heads ?? #644332
03/18/10 06:15 PM
03/18/10 06:15 PM
MD.
V
vttm Offline OP
vttm  Offline OP
V
MD.
I currently have arp head bolts for my eddy heads and I was told not to use the bolts on the eddy's but to use studs instead. Do I need to shelf the bolts and buy some studs or are the bolts ok? The eddy's are for a 440 with 11 to 1 comp and solid roller cam.
Re: Studs or bolts for eddy heads ?? [Re: vttm] #644333
03/18/10 06:20 PM
03/18/10 06:20 PM
the bolts work just fine for that application, as long as they're the reduced hex head style. if it were a high compression motor, then studs would be better.
Re: Studs or bolts for eddy heads ?? [Re: vttm] #644334
03/18/10 07:11 PM
03/18/10 07:11 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i would definitely use studs for the rockers though.
Re: Studs or bolts for eddy heads ?? [Re: vttm] #644335
03/19/10 12:39 AM
03/19/10 12:39 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been using the same arp bolts for almost 10 years............first on my iron headed bb and now w/eddy heads on the same 470.
Re: Studs or bolts for eddy heads ?? [Re: Thumperdart] #644336
03/19/10 12:42 AM
03/19/10 12:42 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We have bolts on my boys 400 Dart with Eddy RPM heads. Been like that for 5 years. I prefer the bolts in a car as it makes it much easier to pull the heads with the eng in the car. Ron
Re: Studs or bolts for eddy heads ?? [Re: 383man] #644337
03/19/10 10:51 AM
03/19/10 10:51 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run bolts on my Stealths with 12.5 compression.Runs on the street and strip.Over 2 years and no problems.Rocky
Chrysler Firepower
Re: Studs or bolts for eddy heads ?? [Re: therocks] #644338
03/19/10 03:17 PM
03/19/10 03:17 PM
MD.
V
vttm Offline OP
vttm  Offline OP
V
MD.
Bolts it will be then. I appreciate the advice.
