Mallory 110 losing prime #64418
05/27/08 10:09 AM
05/27/08 10:09 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
I have a Mallory pump in my Duster and a summit cannister filter (like the fram one) plumbed before it.
Occasionally it will just lose prime and die. Never when driving, usually when idling. The solution is odd looking but effective. I just blow into the filler neck hard and it picks up again.
I thought it might be a blocked tank vent but I verified it was open.
I'm wondering if my pump is too high in relation to the tank level.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Mallory 110 losing prime [Re: CJK440] #64419
05/27/08 03:48 PM
05/27/08 03:48 PM
clearwater,fl
P
postbody65 Offline
postbody65  Offline
P
clearwater,fl
change the filter from the tank to a smaller filter and throw away the fram type filter,it drains down
[url=http://www.postbody65@yahoo.com
Re: Mallory 110 losing prime [Re: CJK440] #64420
05/27/08 04:49 PM
05/27/08 04:49 PM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
Try to mount your pump lower and keep your tank filled.
Re: Mallory 110 losing prime [Re: CJK440] #64421
05/27/08 07:05 PM
05/27/08 07:05 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Mine in mounted about mid level of the tank. The Mallory Tech said that this level was fine, for what ever that is worth. However, I cannot say with confidence that mine is okay as I only have several hours of run time on all the new stuff since its been together.
Also, is the Summit canister a typical paper filter element? Probably not effecting the prime at idle, but the 100 micron mesh/screen type prefilter is often recommended.
I'm going from memory, but last year, were you not questioning if the 100 Mallory was providing enought fuel at the big end of the track? If so, what did you find out?
Re: Mallory 110 losing prime [Re: BSB67] #64422
05/28/08 08:42 AM
05/28/08 08:42 AM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
Yes its a paper filter. I'll have to get under there and look at my setup.
My problem with losing fuel before the traps was due to me having very small needles and seats in the carb.
Re: Mallory 110 losing prime [Re: CJK440] #64423
05/28/08 06:06 PM
05/28/08 06:06 PM
Prospect, PA
Prospect, PA
Let us know what you find as the cause of the losing prime problem.
