EFI tanks...or just remote pump? #641905
03/16/10 03:24 PM
03/16/10 03:24 PM
Austin, Texas
Seank Offline OP
Seank  Offline OP
Austin, Texas
68 cuda…
I have a EFI tank quandary. I am looking at a FAST EZ-EFI setup and for $350 more I can get the kit with an external pump / lines.
If one goes this route I have to replace sending unit and/or modify it with one with a return line tube.
I think my current tank is ok but it should be boiled out as there is some rust and old gas varnish in it as it was off the road for a few years. Estimate expense would be:
$60 to boil, 10 new gasket, 69 for sender, 350 for efi external pump kit = $489 total.
But instead of buying the $350 external pump kit I can buy an internal pump (better setup and one a lot of people use is below) and modify my tank…however every article I have read says to buy a new tank and convert it but I am 80% sure I can boil my old one out:
http://www.tanksinc.com/index.cfm/page/p...=prod/prd84.htm
But…it would require me to cut holes in my trunk to run the lines up from top of the pump as the mopar tank is smooshed up against the trunk floor, no clearance to sneak lines between them.
Or pound down the top of the tank for clearance and not sure if I can do that.
Cost: $60 to boil, 10 new gasket, 69 for sender, internal pump 215, new external fuel aeroquip supply lines $80 = $434 total. Cheaper, quieter and probably safer but I “may” have to cut up my trunk floor to route lines up and out, maybe not.
Or have a custom tank done for the same, I hear they are about $1000 complete. I contacted Ricks Tanks but they need me to send them my old one in as a pattern. Don’t know anyone else doing mopar tanks.
Any ideas?
Sean
Re: EFI tanks...or just remote pump? [Re: Seank] #641906
03/16/10 03:42 PM
03/16/10 03:42 PM
a cornfield near you
BlakDak Offline
BlakDak  Offline
why not have a sump added to the rear?
Re: EFI tanks...or just remote pump? [Re: BlakDak] #641907
03/16/10 04:13 PM
03/16/10 04:13 PM
Austin, Texas
Seank Offline OP
Seank  Offline OP
Austin, Texas
No such EFI pump made. All are installed down from the top of the tank.
Re: EFI tanks...or just remote pump? [Re: Seank] #641908
03/16/10 04:21 PM
03/16/10 04:21 PM
BlakDak Offline
BlakDak  Offline
EFI pump? its either electrical or mechanical.
Run a sump and a external pump, then either use your original pick up as the return line, or cap it off, and only use your sending unit.
I'll have to look at how the pick up mounts in the tank on my Valiant, but I am pretty sure you could modify it, and use a in tank electric pump.
As far as a return line, do you want to use one, or are you thinking you have to use one?
Re: EFI tanks...or just remote pump? [Re: BlakDak] #641909
03/16/10 05:21 PM
03/16/10 05:21 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Well I have a much cheaper way through this but there's more than one way to do it. Add a sump to the bottom of your tank and run that to an external in-line walbro efi fuel pump model # GSL-392. Pump costs around 80-100 bucks new and you can either fab the sump yourself or buy a prefabbed ~$60 I think, and weld it on your tank. Pump draws out the fitting in the sump and you can stick the return line through your stock fuel sender. Hell of a lot less than 400 bucks.
Re: EFI tanks...or just remote pump? [Re: DaytonaTurbo] #641910
03/16/10 05:28 PM
03/16/10 05:28 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
As long as you don't need more fuel than the Walbro can deliver (about 550 HP).
In the above picture the sump has two fittings. One can be the outlet from the pump and the other can be the return line.
BTW: The internal pump is nice because you won't hear it.
Re: EFI tanks...or just remote pump? [Re: Mopar_Rich] #641911
03/16/10 05:37 PM
03/16/10 05:37 PM
BlakDak Offline
BlakDak  Offline
wanna bet?
well maybe not in a big muscle car
but I can hear one in my Rx7, and Eclipse, no where near as loud as a holley external pump I had in the 90's on a Duster.
Re: EFI tanks...or just remote pump? [Re: BlakDak] #641912
03/16/10 07:45 PM
03/16/10 07:45 PM
IN
ahy Offline
ahy  Offline
IN
I went through this choice once and need to do it again.
I'm making about 550 HP in a Challenger and wanted a setup that could grow. I went with an A1000 frame rail mounted pump and (eventually) a 1/2" pickup. I haven't been too happy with it. With an external EFI pump and stock pickup, going below 1/2 tank is not recommended. I like to travel and the Challenger tank isn't that big to start with so its a range limiter. The car will run with less fuel in the tank but with increased risk of pump cavitation or momentary fuel starvation.
Also I've learned the A1000 pump is probably too big to run with a stock type pickup (even 1/2") and AN8 line feeding it. In hot weather, it cavitates. The cavitation combined with vent problems for a little while killed one pump and sent me home on a flatbed.
A sump added to the stock tank as posted above would be one fix for the cavitation and 1/2 tank requirement. I'm just not sure I want to have it plus the fuel lines hanging down under the car. If I hit a bump + dip at speed and snagged that setup it wouldn't be pretty.
A smaller pump - but still big enough for the engine - would reduce cavitation. I'm right on the dividing line between the smaller pumps and the big ones however. A Walbro would probably work fine but have little room for growth.
The ideal solution would be a custom tank with built in pump - either Walbro or A1000. No cavitation, no limits on fuel level and much less noise. Its just expensive.
My bandaid is to slow down the A1000 with reduced voltage. 60' of #12 wire on the pump power feed has reduced voltage by about 1.3v. I'll try that and see if it works.
Any other ideas welcome!
Re: EFI tanks...or just remote pump? [Re: ahy] #641913
03/16/10 08:16 PM
03/16/10 08:16 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
You know they make a pump controller that does this for you...
Re: EFI tanks...or just remote pump? [Re: Mopar_Rich] #641914
03/16/10 09:28 PM
03/16/10 09:28 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Couple of mine from my Cuda:
My other Project:
Re: EFI tanks...or just remote pump? [Re: Mopar_Rich] #641915
03/16/10 10:01 PM
03/16/10 10:01 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
One can always plumb up 2 3/8" lines and feed 2 walbro's for upwards of 1100 horsepower capable as well as having redundant fuel supply in case one pump fails. Just an idea that i've seen on high horsepower supras.
Re: EFI tanks...or just remote pump? [Re: Dragula] #641916
03/16/10 10:02 PM
03/16/10 10:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Hey Sean, it's me Steve, long time no see.
Anyway, when I converted my Diplomat to EFI (remember that car?) I used the stock tank. I went with an external pump initially, it burned out twice on me so I went with an internal pump. Modified the pick up to mount the pump on it. At less than half a tank that unbaffled tank would let the pump suck air and kill the engine.
I did some looking around in yards for an EFI tank I could make fit the Diplomat with no luck.
If you need to come out the top of the tank with lines you can simply use a spacer to space the tank down an inch or so for enough room.
To be honest, if money weren't an issue I'd have a new stock tank modified by tanks, inc. to include an baffled sump and internal pump.
http://www.tanksinc.com/index.cfm/page/p...prod/prd121.htm
BTW, bottom mounted add on sumps are illegal and dangerous and I don't care how many people say they've run it with no problem.
Don't be the exception.
Re: EFI tanks...or just remote pump? [Re: Supercuda] #641917
03/17/10 01:06 AM
03/17/10 01:06 AM
Manitoba, Canada
Manitoba, Canada
And that's what I would do before I ever dropped that kind of coin on an aeromotive pump. Most prefabbed aftermarket sumps have two outlets making it perfect for twin pumps. I wouldn't run the return to one of those fittings just because you're cycling the heated return fuel right back into the sump area and you can easily add the return to your stock pickup.
Also, my brother runs an external in-line walbro 255 on his 83 dodge rampage. 2.2L turbo with a bone stock small diameter exhaust with stock muffler. I do not heat the walbro when the engine is running.
Illegal where and dangerous how? The way my car sits in the back, the fuel tank is so high up there's more room between the bottom of the sump and the ground than there is between the bottom of my rockers and the ground. I'd have to back over a tree stump or a fire hydrant to hit that thing!
Re: EFI tanks...or just remote pump? [Re: DaytonaTurbo] #641918
03/17/10 01:51 AM
03/17/10 01:51 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Another thing that can be done is to use a small pump inside the tank to push the fuel to the main remote mounted pump.. I have a NOS pump from a 85 Ford Truck that was originally installed throught a standard small sized opening before the big 6" hole became the norm.. These pumps couldn't push high PSI like typical EFI pumps but what they do is provide a good supply to the inlet of a typical frame mounted pump...
And because the pump easily passes through the standard small opening with a little work it could easily be adapted to the sending unit of your choice..
Re: EFI tanks...or just remote pump? [Re: DaytonaTurbo] #641919
03/17/10 01:56 AM
03/17/10 01:56 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
There's a company at here in So Cal that builds aluminum gas tanks that are drop in replacements (except for a join in the fill tube IIRC).
http://www.hotrodcitygarage.com/indexA.html
He comes out to Spring Fling. From what I hear they are a good deal.
I just saw him at the last local swap meet. He can build you a tank that take a inside pump, but he advises against it. He says to change/repair the pump it's a pain. And he said there are external pumps that are not noisey. His words I dunno.
Quicksilver440 just bought one and was very happy: https://board.moparts.org/ubbthreads/show...rue#Post5790175
Re: EFI tanks...or just remote pump? [Re: DaytonaTurbo] #641920
03/17/10 06:17 PM
03/17/10 06:17 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It's illegal in the US, Federal Motor Vehicle Safety Standards. I know nothing about Canadian law.
Unsafe, you betcha. What happens when you kick up so debris and it knocks a hose off the bottom sump setup? The whole tank dumps out.
With a top exit setup, even with an internal electric pump, you don't have that problem. With an external pump, it sucks air. With an internal pump, you shut of the key, no pump. And don't tell me there is no possibility you could kick up some debris, unless it's a trailer queen.
Re: EFI tanks...or just remote pump? [Re: Supercuda] #641921
03/17/10 06:51 PM
03/17/10 06:51 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
Does anyone here with Fuel Injection add a 1 gal or so sump tank after the main tank, but before the high pressure pump (basically fed by a low pressure pump) to eliminate as much need for a baffled tank? Just curious as I'm trying to plan out my fuel system for EFI as well. Hope this helps the OP as well!
Re: EFI tanks...or just remote pump? [Re: Alikazam] #641922
03/17/10 08:11 PM
03/17/10 08:11 PM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
I know for RX-7 track guys a surge tank is practically mandatory.
Re: EFI tanks...or just remote pump? [Re: Mopar_Rich] #641923
03/17/10 08:59 PM
03/17/10 08:59 PM
IN
ahy Offline
ahy  Offline
IN
I've seen those and looked them up again last night. They're a little expensive but it sounds like they drop the voltage with pulses instead of a constant low voltage which is easier on the pump. Plus they can go to full power if needed.
Min pump speed is adjustaable but I didn't see how much they can actually slow the pump down though?
Re: EFI tanks...or just remote pump? [Re: Supercuda] #641924
03/17/10 09:17 PM
03/17/10 09:17 PM
BlakDak Offline
BlakDak  Offline
Hmmm, no cop has ever said anything about the cars I had them on.
Kick up debris to knock AN lines off? I dunno about you, but if its that big, I'm not going to hit it, and if I did, it'd probably take the car out.
Come on man, get real.
