Page 2 of 3 1 2 3
Re: Moser or Strange Race Axles? #640374
03/15/10 05:49 PM
03/15/10 05:49 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
I recommend Moser. The customer service is by far the best of them all, minus Dr. Diff, and they are the first contingency check you will receive after winning. They will build you a set of axles any way you want(gun-drilled, star-flanged) and are easy to work with. For my money, I'll run a Moser axle anyday.
Re: Moser or Strange Race Axles? #640375
03/15/10 07:28 PM
03/15/10 07:28 PM
Byron, NY
W.I.N. Racing Online content
W.I.N. Racing  Online Content
Byron, NY
My experience says go with Strange. I have used all three but for this for this disscussion I say Strange. The manufacturing quality is better.
eg. The sets of Moser axles with 5/8 studs that I have used are a pain in the a$$. The wheels take a lot of convincing to get on/off. All the starnge axles with 5/8 studs that I have used usaly go on/off fairly well.
I now steer customers towords Strange.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Moser or Strange Race Axles? [Re: W.I.N. Racing] #640376
03/15/10 08:19 PM
03/15/10 08:19 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I ran Strange on my first race car.....eight years with no problems , great customer service when ordering.
This time around I went with Moser and they have been awesome with one minor hiccup.
I first did the car as a streeter , then after a couple boring years , decided to get serious again.
I had my housing narrowed and wanted the axles shortened too.
I called them and got the " send them in " from one guy ....... then I read on their web site that they need to take 3 1/2 " off to get past the original splines.
I am only shortening them 2 1/4 ".
I called back and a different guy ( salesman ? ) told me I needed to buy new.
I called a couple people who do this , and was told that they can pick up on the original splines.
So I called them back and spoke with a third guy who said " send them in "
In they went.
I am waiting for the call with pricing , but I don't see any problems.
Re: Moser or Strange Race Axles? [Re: tubtar] #640377
03/15/10 09:28 PM
03/15/10 09:28 PM
Anonymous OP
Anonymous OP
so are you saying i can send back my strange axles and get them shortened. i need 1-1/2" off each side and i want 5/8th studs put on as well. i love my old strange axles.
Re: Moser or Strange Race Axles? #640378
03/15/10 09:33 PM
03/15/10 09:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I never considered Moser as race axles, I have a Moser dana 60 under my street car. Drove up there and picked it up, great people.
If your looking for race axles, go Strange or better yet Mark Williams, the best there is.
Re: Moser or Strange Race Axles? #640379
03/15/10 10:23 PM
03/15/10 10:23 PM
Cincinnati, Ohio
Cincinnati, Ohio
Then you can use trick aluminum lug nuts, MW nuts here. I had a set in titanum also.
Re: Moser or Strange Race Axles? #640380
03/15/10 10:32 PM
03/15/10 10:32 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
If the splines are long enough , you could probably lop 1 1/2 " off and run them.
I don't know how much spline you have engaged , but in most applications , it is under 2 " I think.
Cold cut them and stone the burr off and I think you'd be dookin in tall cotton.
The studs ???? not so much I think.
Drilling would be less of a problem than tapping.
Post deleted by Defbob [Re: Challenger 1] #640381
03/16/10 01:15 AM
03/16/10 01:15 AM
Anonymous OP
Anonymous OP
Re: Moser or Strange Race Axles? #640382
03/16/10 02:11 AM
03/16/10 02:11 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Moser axles are a Sportsman axle, made at a price. They're strong, but the two sets I had the machining quality left a little to be desired. The last set I ordered were Mark Williams Masterline axles. Slightly dearer than Moser's, but finished much better.
A race application, buy Mark Williams and have them cut the spline style you want. They will cut a spline to suit any spool. Strange 12 Bolt drop out centers used in Comp Eliminator, many racers are using MW axles with them
AL....
Alan Jones
Re: Moser or Strange Race Axles? [Re: LA360] #640383
03/16/10 08:09 AM
03/16/10 08:09 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
I bought some strange 35 spline and in six years one broke.I then bought a pair of mosers 12 years later they still look new.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: Moser or Strange Race Axles? [Re: moparmxz] #640384
03/16/10 06:19 PM
03/16/10 06:19 PM
Anonymous OP
Anonymous OP
from what i was told, strange wont cut their own axles and respline them.
i know this 1st hand. they said buy new axles.my vote is moser or mark williams, always seem to have drama over at strange for some reason or another.
Re: Moser or Strange Race Axles? [Re: moparmxz] #640385
03/16/10 07:48 PM
03/16/10 07:48 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
That Bunker Hill in the background?
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: Moser or Strange Race Axles? #640386
03/17/10 02:44 AM
03/17/10 02:44 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Any "race" axle that can be resplined is softer and heavier than it should be.
High end axles are machined BEFORE they are hardened. In other words, the splines stick out of an hour-glass shaped shaft, instead of being cut into an already hardened sraight shaft. The hour-glass design minimizes a stress riser where the axle splines and spool splines meet.
Neither Strange nor Mark Williams race axles can be resplined.
Re: Moser or Strange Race Axles? [Re: DoctorDiff] #640387
03/17/10 05:33 AM
03/17/10 05:33 AM
Russiaville, IN
mopar376d Offline
mopar376d  Offline
Russiaville, IN
I agree with Randy.
I broke a strange in one car and twisted another in the Belvedere. Don't know the exact time they where ran but they where older.
Moser axles in both cars trouble free for the last 5 years or better.
Why does divorce cost so much? Because it is worth it!!!!!
Re: Moser or Strange Race Axles? [Re: W5Duster436] #640388
03/17/10 06:47 AM
03/17/10 06:47 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Yes thats at Bunker Hill,my favorite place to be in the summer time.
Re: Moser or Strange Race Axles? [Re: moparmxz] #640389
03/17/10 07:41 AM
03/17/10 07:41 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Twisted a lot of Strange axles in the past.We have run Mosers the last 5 years in most our cars with no problems.Service and delivery are second to none. (FYI)We are using most in 8 to 10 second bracket cars.
Re: Moser or Strange Race Axles? [Re: B G Racing] #640390
03/17/10 11:26 AM
03/17/10 11:26 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I've seen every brand twist, including Moser.
Re: Moser or Strange Race Axles? [Re: DoctorDiff] #640391
03/17/10 11:38 AM
03/17/10 11:38 AM
Cincinnati, Ohio
Cincinnati, Ohio
Yup, even this 40 spline MW live axle. Twisting is better than the alternative.
Re: Moser or Strange Race Axles? [Re: DoctorDiff] #640392
03/17/10 11:52 AM
03/17/10 11:52 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Then what is the reason for using Strange specifically?Moser and other brands should be considered for application and cost.The same logic applies to why chose Strange over MW.No one's saying Strange is not a good axle,but for the cost,delivery and ease of ordering we find Moser easier to deal with.We bought a lot of Strange early on but over time we found that to order anything you best have every demension including your shoe size,and that didn't guarantee you got what you ordered.For everyday bracket cars Moser fits the budget next level would be Strange with MW being the ultimate choise for us.
Re: Moser or Strange Race Axles? [Re: B G Racing] #640393
03/17/10 07:41 PM
03/17/10 07:41 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Retail cost is virtually the same between Moser 1541 axles and the lighter, higher grade Strange 4140 (cr-mo) shafts.
FWIW, I prefer Dutchman street/strip 1541 axles for cost, delivery and ease of ordering. For a race only axle, the value of the Strange product is hard to beat.
Here is a retail price comparison:
Dutchman 35 spline 1541 axles, bearings and 1/2" studs $370 pair
Moser 35 spline 1541 axles, bearings and 1/2" studs $445 pair
Strange 35 spline 4140 Pro Race axles, bearings and 1/2" studs $450 pair
Anyone who has a problem dealing with Strange Engineering can order their products through me .
Page 2 of 3 1 2 3
