E-body side window installation? #639788
03/14/10 01:43 PM
03/14/10 01:43 PM
KS
MoparKansas Offline OP
KS
I took my 73 Challenger apart eons ago and now I am getting ready to put it back together. Is there an online diagram or step by step procedure to putting the windows and tracks back in that anyone knows of?
Re: E-body side window installation? [Re: MoparKansas] #639789
03/14/10 02:43 PM
03/14/10 02:43 PM
midwest
I
intragration Offline
I
midwest
I'm in the same boat as you, except I have the body manual that shows the steps. I'll try to scan them in and post.
Re: E-body side window installation? [Re: intragration] #639790
03/14/10 09:38 PM
03/14/10 09:38 PM
Ft. Worth, TX
TransAm Twins Offline
Ft. Worth, TX
This boat is getting full fast. I've got the same dilemma.
Re: E-body side window installation? [Re: TransAm Twins] #639791
03/16/10 10:40 AM
03/16/10 10:40 AM
KS
KS
BTT - anyone have a diagram?
Re: E-body side window installation? [Re: MoparKansas] #639792
03/16/10 11:21 AM
03/16/10 11:21 AM
canada
mridolfo Online content
mridolfo  Online Content
canada
Not sure if this helps.
5868655-QuarterWindow.pdf (4190 downloads)
Re: E-body side window installation? [Re: mridolfo] #639793
03/16/10 11:22 AM
03/16/10 11:22 AM
canada
canada
Scan 2
Re: E-body side window installation? [Re: MoparKansas] #639794
03/16/10 01:05 PM
03/16/10 01:05 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Putting side glass in is my favorite part of the restoration, however typing is not. Get yourself a FSM and follow the instructions...It's just too much to explain
CHECK OUT MY NEW WEB SITE !
Re: E-body side window installation? [Re: anlauto] #639795
03/16/10 02:51 PM
03/16/10 02:51 PM
KS
KS
Thanks for the drawings, those will help immensely! Do you have one for the door windows as well?
Alan - you are a sick dude. These dang regulators look like some type of Rube Goldberg contraption to me! Lots of parts to accomplish a simple task! I put power regulators in my son's jeep in about a half an hour - I'm thinking these are a full day project - maybe a weekend. I probably would be time ahead to buy a service manual. These windows and the four speed linkage are the parts I am dreading most about putting this car back together. The four speed linkage looks pretty simple, but I am converting this car and have never seen it together to know what it is supposed to look like. What holds the rear glass in the lower channel can you just use glass glue?
Re: E-body side window installation? [Re: MoparKansas] #639796
03/16/10 06:34 PM
03/16/10 06:34 PM
Omaha
road Offline
road  Offline
Omaha
Just went through the install last fall for the rears on my 73. If you want pics, let me know. Hardest for me was how to install the stop.
Re: E-body side window installation? [Re: road] #639797
04/03/10 10:44 PM
04/03/10 10:44 PM
KS
KS
OK - so I have much of the stuff figured out. Fronts - You need to intall the slider bracket near the rear of the door first and then the regulator. Then the front and rear slides some of which are marked left and right if you look closely. I am still needing to get the pieces that bolt the long bracket to the window itself from R/T Specialties so the windows aren't in,but well on their way.
Rear - firgured it was much the same so I put the regulator in first since the piece the square slider goes into was already in the door. The square plastic slider goes into the middle of the slide bracked and the round roller goes on the outside. I still need to polish the stainless piece that goes in front of the window on both sides, so I am at kind of a standstill there.
For any of you dreading the process the worst part is probably cleaning the old grease and grime off of the rollers and brackets. Good Luck to you all!
Re: E-body side window installation? [Re: MoparKansas] #639798
04/04/10 02:14 AM
04/04/10 02:14 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Courtesy of Barry at Hamtramck-Historical
Good reading.
Body - 70 sh 48 to 65
1970 Passenger Car Service Highlights
Re: E-body side window installation? [Re: Snoopy] #639799
07/16/11 11:52 PM
07/16/11 11:52 PM
midwest
I
I
midwest
Ha ha, cleaning the grease. I have a parts washer, that was unfortunately the easy part. Just got finished with the passenger door. This had to be the most difficult, most unsatisfying job in the history of the automobile. The worst part about it was when I got half-way through, after two hours of struggling and watching the glass bounce back and forth against the metal brackets in the window well, and discovering that the front lift channel fastener, on the far side of the glass, hadn't been installed...wasn't called for in the FSM (as the front slides were). I can't DESCRIBE how much fun it was to get this installed through that little 1 inch slot by the window crank. I certainly wasn't about to undo the whole job and risk damaging the glass more just to put this on, so I did it the hard way.
On the upside, I only have one more piece of glass to install on the car, and then I get to adjust it all. THEN I can put in all the interior panels and button up the interior. Amazing how this one, hideous, awful job is holding up the entire rest of the restoration, the fun parts.
Re: E-body side window installation? [Re: intragration] #639800
07/17/11 11:41 AM
07/17/11 11:41 AM
Yeah, it's lots of fun isn't it, lol. Then there's the time spent on adjusting it and getting everything to line up just right.
Re: E-body side window installation? [Re: ] #639801
07/17/11 02:37 PM
07/17/11 02:37 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
I will need to install my window stuff before too long also. Since the car is painted, my fear was having the mechanism fall into the panel and denting it from the inside out. Someone suggested that I put a piece of cardboard in the door/quarter area while installing stuff to prevent accidental internal denting. Don't know if anyone else has done this but had planned on trying it for my install.
Joe
65 Barracuda
70 Challenger
Re: E-body side window installation? [Re: jrwoodjoe] #639802
07/17/11 04:42 PM
07/17/11 04:42 PM
midwest
I
I
midwest
I suppose what you're saying would be possible to happen, but I would think pretty unlikely. Anything that falls is going to more than likely just hit the horizontal bottom area of the inside of the door.
My bigger concern was protecting the glass from scratches. I went so far as to cover it with some 3 mil plastic sheeting. This became such a huge pain in itself, I just removed it and installed the glass bare. Maneuvering with the plastic made it MORE likely I would damage the glass.
Having had more time to think about this job, and having adjusted the glass since my last post, I retract what I said about the job being unsatisfying. It was a huge pain, but in the end, it works pretty well, and it does give the car a big boost in feeling of completion. If you take your time, it's relatively simple to get the glass adjusted really well. After about 30 minutes, I had a perfect seal around both pieces of side glass. The only strange problem is the door glass doesn't quite want to close all the way when the door is closed, it closes flush with the seal, but doesn't overlap the way it's supposed to. Closing it with the door open and then closing the door eliminates this problem. I guess I could really crank down on the handle and jam it shut, but my original regulator was ruined this way, I'd rather not strip the teeth off this one too.
Re: E-body side window installation? [Re: intragration] #639803
07/17/11 07:53 PM
07/17/11 07:53 PM
Chicagoland
cudastruction Offline
Chicagoland
Maybe the real problem is that the glass that you have is slightly mis-shaped...?
Re: E-body side window installation? [Re: cudastruction] #639804
07/17/11 11:52 PM
07/17/11 11:52 PM
midwest
I
I
midwest
There could be something to what you're saying. I did notice that additionally, the new glass doesn't line up exactly with the "aged in" line of the original glass in the weatherstripping. Still, when closing the window with the door open and then shutting the door, the new glass overlaps the weatherstripping just fine. If you close the window with the door closed, it doesn't close as far, and when you then open the door, you can still close the glass a little further. Probably this will be a non-issue with new soft weatherstripping.
