Carpet install???? #636920
03/11/10 06:42 PM
03/11/10 06:42 PM
wisconsin
swifter Offline OP
swifter  Offline OP
wisconsin
Any hints as to installing carpet in my Duster for the first time???What do I do along the doors where the wire troughs are???Thanks Steve--This is my first time
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: Carpet install???? [Re: swifter] #636921
03/11/10 06:46 PM
03/11/10 06:46 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the carpet goes over the wire trough and tuck up under the sill plates..
remove the kick panels too...
you might want to get a can of spray adhesive also to spray up on the firewall to help hold it in place.
i used a soldering to burn holes in the new carpet where the bolts go thru for the seat...
Tony
70 AARCuda Vitamin C
Re: Carpet install???? [Re: 70AARcuda] #636922
03/11/10 06:55 PM
03/11/10 06:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Lay it out where it can flatten on it's own for a couple of days before installing it.
Re: Carpet install???? [Re: stumpy] #636923
03/11/10 07:47 PM
03/11/10 07:47 PM
at large
moparphillie Offline
at large
I agree with Stumpy, but it would be even better if you could lay it out flat in the Sun. If you can, you will notice a big improvement when you start to install the carpeting.
Good Luck...
Re: Carpet install???? [Re: 70AARcuda] #636924
03/11/10 09:44 PM
03/11/10 09:44 PM
yes do not use a drill
Re: Carpet install???? [Re: RapidRobert] #636925
03/11/10 10:28 PM
03/11/10 10:28 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
Install all of the seat and seatbelt bolts then install the carpet over them. Then when you are ready cut or burn the carpet holes right where the bolts are. Way better than stabbing and cutting in the wrong spots.
Re: Carpet install???? [Re: swifter] #636926
03/12/10 06:37 AM
03/12/10 06:37 AM
Rutherfordton NC
BarryBum Offline
Fruit Of The Loon
BarryBum  Offline
Fruit Of The Loon
Rutherfordton NC
The carpet should be cut long. Make sure all your excess that you cut is way up under the firewall. In other words, push it forward as far as you can then trim at the front.
