73-76 A-Body Spool Mount K-Frame, Pros/Cons
#63483
05/25/08 09:12 PM
05/25/08 09:12 PM
Posts: 1,230 Pittsburgh, PA
wayfarer1
Pittsburgh, PA
I am in the process of pulling the junk 318 and 904 from my 72 Swinger to start the resto. I can see evidence of some pretty heave pitting and surface rust on the stock V8 K-frame. I am thinking about replacing it and I know where there are 2 spool type k-frames, one has a complete disc brake setup on it.
My question is what are the benefits of the spool k-frame over the earlier biscuit type and are there and problems with the newer design that I should be concerned with.
Any help will be appreciated, Joe
Current Project: 72 Roadrunner 340/727/Petty Blue/White Roof Strobe Stripe/Black Bucket Interior
71 Demon project
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons
[Re: wayfarer1]
#63484
05/25/08 09:43 PM
05/25/08 09:43 PM
Posts: 469 In a van, down by the river
jmf340
I don't know about any design flaws or benefits to the newer style spool mount, other than I feel it is easier to get the motor mount in the desired frame mount and slide a bolt through. It also tells you that the motor is situated correctly. Just my opinion though.
Got Mopar???
[Re: jmf340]
#63485
05/25/08 09:46 PM
05/25/08 09:46 PM
spool mount are superior in everyway.
#63486
05/25/08 10:16 PM
05/25/08 10:16 PM
Posts: 27,483 So Cal
autoxcuda
So Cal
![](/ubbthreads/images/graemlins/iagree.gif)
![](http://www.cpwclub.com/KmbrAssy.jpg)
[Re: autoxcuda]
#63487
05/26/08 08:04 AM
05/26/08 08:04 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
only negative is I think the front track on the later big-bolt pattern K's are a little wider...
[Re: patrick]
#63489
05/26/08 03:15 PM
05/26/08 03:15 PM
autoxcuda
So Cal
Like Rocketride said, thats from the spindles/rotors. So if you do the factory type BBP conversion to a 67-72 A-body, you be at the same width.
I had the BBP conversion in my 68 K-member. Then I switched to just the 73-76 K-member. No width change and no engine height change either.
[Re: autoxcuda]
#63490
05/26/08 08:26 PM
05/26/08 08:26 PM
wayfarer1
Pittsburgh, PA
So if I use the BBP disc brakes I have with the 73 spool k-member I should be good?
I have to get the old motor out first and evaluate the condition of the original k-frame before I make a final decision on replacing it.
Thanks for the info! Joe
71 Demon project
[Re: wayfarer1]
#63491
05/26/08 08:56 PM
05/26/08 08:56 PM
autoxcuda
So Cal
Yes, that will be fine. If have to, you can re-use your 72 biscuit type K-member too.
Do any of these setups have lower control arms with sway bars tabs??
The one on the left is a 73-76. The one of the right is a 67-72
![](http://www.cpwclub.com/LwrCntls.jpg)
[Re: boden]
#63494
05/28/08 10:04 PM
05/28/08 10:04 PM
Posts: 515 Dayton, Ohio
65cuda
mopar addict
mopar addict
Dayton, Ohio
you can buy a sway bar kit. another great thing about the spool mount is the sway bar goes through the k and doesn't hang below. also your not going to pull a motor mount apart.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers GarysMocars Legendary Dealer
[Re: boden]
#63496
05/28/08 11:14 PM
05/28/08 11:14 PM
Posts: 1,024 In the twisties
RokketRide
super gas
super gas
In the twisties
One con is that to you cannot install a 5.7 hemi with the TTI brackets using spool mounts. I actually cut 2 k-frames apart and made a hybrid. Top half is 72- for engine mounts, bottom half is 73+ style for the throught the k-frame sway bar.
![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: RokketRide]
#63497
05/29/08 12:21 AM
05/29/08 12:21 AM
wayfarer1
Pittsburgh, PA
Well, I found out today that a friend has a spool mount k-frame that I will be buying from him for a good price. He does not have the mounting brackets though. I know where there are 2 V8 Darts with the brackets still attached.
Is there an easy way to remove the mounting brackets with the engine still in the car or will I have to have the motor pulled to get them off?
Thanks to all for the great info!
71 Demon project
[Re: wayfarer1]
#63498
05/29/08 12:34 AM
05/29/08 12:34 AM
65cuda
mopar addict
mopar addict
Dayton, Ohio
i got mine from advance auto parts. new and ready to bolt in.
[Re: 65cuda]
#63499
05/29/08 12:45 AM
05/29/08 12:45 AM
autoxcuda
So Cal
Yes, spool mount motor mounts have the motor mount brackets integrated with them.
The long bolt that goes through the motor mount and to the K-member is sort of special. The washer fit the k-frame and IIRC, it's swaged in the center so it doesn't spin when you tighten it?? ![](/ubbthreads/images/graemlins/smilie_help.gif)
[Re: autoxcuda]
#63501
05/29/08 12:50 AM
05/29/08 12:50 AM
sounds bout right.
[Re: RokketRide]
#63502
05/29/08 01:56 AM
05/29/08 01:56 AM
autoxcuda
So Cal
Crap, I gotta find a set of those, my parts car didnt have them.
Might be available from dealer.
Same as any junkyard FMJ and R-body bolt. Maybe even others.
