Mini Alt pictures for Scratchin #634314
03/08/10 07:33 PM
03/08/10 07:33 PM
Connecticut
FurryStump Offline OP
Connecticut
Here's three pictures, the first Spacer in the black square is 1/2",in the yellow is 1/4",in the blue is 1 1/2".
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Mini Alt pictures for Scratchin [Re: FurryStump] #634315
03/08/10 07:35 PM
03/08/10 07:35 PM
Connecticut
Connecticut
The second shows why I had to pie cut the swing arm to tighten the radius.
Re: Mini Alt pictures for Scratchin [Re: FurryStump] #634316
03/08/10 07:40 PM
03/08/10 07:40 PM
Connecticut
Connecticut
It is still a touch to far forward but never had an issue after 8,000 miles. The flat front of the Eddy head is the issue
Re: Mini Alt pictures for Scratchin [Re: FurryStump] #634317
03/08/10 08:21 PM
03/08/10 08:21 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Is this a Denso alt. that uses the round 3 wire pigtail plug-in?
Re: Mini Alt pictures for Scratchin [Re: cruzin] #634318
03/08/10 08:33 PM
03/08/10 08:33 PM
scratchnfotraction Offline
thanks for the skoolin very detailed pics
I will mark this to favs and use for a referance later...
the alt I have is ext reg and has the double ears as the pivot point
did you drill a hole in the one bracket for the swing arm?
on mine with brackets it on the long lower wp bolt
but I am using the template of the one in the archives that you print out and is correct size
better brush up on how to wire a int reg alt up on my 85 truck while I am at it
Re: Mini Alt pictures for Scratchin [Re: scratchnfotraction] #634319
03/08/10 09:28 PM
03/08/10 09:28 PM
Connecticut
Connecticut
Yes it is the Toyota 4runner Alt. with the round plug, I used female spade connectors.
No I didn't have to drill any holes in the triangle bracket piece. Just modified the swingarm a small amount.
Re: Mini Alt pictures for Scratchin [Re: FurryStump] #634320
09/02/10 09:07 PM
09/02/10 09:07 PM
reread and looky see pics
Re: Mini Alt pictures for Scratchin [Re: scratchnfotraction] #634321
09/02/10 09:23 PM
09/02/10 09:23 PM
TN
'84 D150 Shorty Offline
Pickup Man
Pickup Man
TN
This toyota alt and the late model unit in a 92 dodge truck should be the same right?
Re: Mini Alt pictures for Scratchin [Re: '84 D150 Shorty] #634322
09/02/10 10:23 PM
09/02/10 10:23 PM
no
the late model truck should have the external regulator and use the stock one on you truck
the toyo is a internal reg and needs wires added and mods to work
it was pics on a sb..looking at the spacers that was used to space it out
I think it will flip over and bolt up with stock non a/c sb pullys
I was going that way for the sb and never got another mini alt yet or finished the brackets
just did the mini starter and alt on the 440 truck
