Best Choice On A Intake ??
#633274
03/07/10 09:06 PM
03/07/10 09:06 PM
Posts: 2,655 western PA
mopar4ya
western PA
Helping out a friend with a 440 build. He was looking to pick up a good used intake and asked what I thought he should be looking for. So, I am open to a good selection of intakes that would work good for this combination. 440 .030 over using a KB237 set at 0 deck height. FelPro 8519PT head gaskets and 66 small valve closed chamber heads. Heads have been bowl ported and cleaned up. Compression at 11:1 and is using a 509 Mopar performance cam. He is putting this in a 66 Belvedere that has a 3000 stall converter and 3:91 gears. Thanks Dan. ![](/ubbthreads/images/graemlins/beer.gif)
Re: Best Choice On A Intake ??
[Re: mopar4ya]
#633277
03/07/10 09:33 PM
03/07/10 09:33 PM
Posts: 10,559 Rittman Ohio
fourgearsavoy
Rittman Ohio
Performer RPM or Torker II would be good.The RPM will be about $100 more than the Torker II ![](/ubbthreads/images/graemlins/shruggy.gif) He has enough gear and converter to use the single plane ![](/ubbthreads/images/graemlins/Twocents.gif) Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#633278
03/07/10 10:10 PM
03/07/10 10:10 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
it really isnt going to matter much as to what he gets. he first needs to fix his miss matched componente.
with that 509 cam being a high RPM cam and the small port/valves heads not being high flow heads he has a major problem.
So IMO with a much better cam and set of 906/346/452 heads a Street Dominator or a Performer RPM and he is going to have a killer engine..
I am truckless..
[Re: 340SHORTY]
#633279
03/07/10 10:36 PM
03/07/10 10:36 PM
mopar4ya
western PA
340SHORTY, he hasn't bought the cam yet. He does have the rotating assembly ready to go into the block. Since he has the pistons, should he rethink the cam choice, or is there a better head that would still get him the 11:1 compression that he wants. The other option would be to machine his heads for the larger valve ?, since they have had some port work. Or do these heads just not flow like a 906 etc.. What would be his cheapest route using the bottom end he has to maximize the performance of this combo?
Thanks Dan ![](/ubbthreads/images/graemlins/beer.gif)
[Re: ahy]
#633284
03/08/10 12:20 AM
03/08/10 12:20 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
66 heads will be 516's not 915's. 11:1 is a nice match for that cam, and stall speed. I agree that the small valve 516's are less than ideal, but it'll run. I wouldn't be afraid to try it before I poured my money into aluminum heads. ![](/ubbthreads/images/graemlins/Twocents.gif) It'll be iffy on pump gas for sure but a smaller cam won't help. The compression has to be reduced if that ia a concern. I suppose that would ba a plus to the eddy's too, in that the alum head will work with pump gas at 11:1 and that cam.
[Re: 383man]
#633286
03/08/10 07:28 AM
03/08/10 07:28 AM
mopar4ya
western PA
The car is used for weekend cruising and he is mixing fuels. I didn't want to see more than 10.5 compression, but he seems to think he wants 11. Will he be fighting detonation at 11.1? I have not cut the heads yet, so the compression number can be changed. It's been awhile since I looked at the heads, but I know they are a closed chamber small valve and I thought they were 915's. Did the 67 440 HP engines with the 915's flow better, or was it the same casting/ports with a larger valve only. Would this combo he has work better with,say a 906 and a little less compression and still use the 509 cam? I think he will be happier with a engine that makes a ton of bottom to mid range torque for what he wants to do. Top end is not his thing, smoky burn outs are ![](/ubbthreads/images/graemlins/biggrin.gif) Thanks Dan ![](/ubbthreads/images/graemlins/beer.gif)
[Re: mopar4ya]
#633287
03/08/10 09:27 AM
03/08/10 09:27 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
RPM performer hands down (Holley SD good too) 509 cam degree it in to 102 or 103 intake installed centerline (max lift) My big big vote is to bite the bullet and get RPM heads no fuel issues with a 509 cam will be able to run 91 octane. If you must but long before you spent ![](/ubbthreads/images/graemlins/Twocents.gif) on a crapy old poor poor flowing heads go with 440 source. I just finished hand porting a set and they "ARE NOT EDELBROCKS" no way they will flow perform or match an eddy!!!!! (maybe close after hand porting) But they will out flow even a hand ported iron heads and still allow 91 octane and I'll bet they will produce 75to 100 more hp than those 66 516 heads Please don't use those 45 year old crack prone million heat cycle iron heads unless they have new valves and guides (you don't want a million heat cycle valve breaking off and hammering the motor apart) new valve springs, retainers and keepers. AND they must be free with all this done or you are throwing the money in the toilet. So if someone gives you a set of done fresh all new 516 use them But if you have to pay anything for them run!!!! ![](/ubbthreads/images/graemlins/beer.gif)
Re: Best Chice On A Intake ??
[Re: gch]
#633288
03/08/10 11:36 AM
03/08/10 11:36 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Holley Sd is about the best all around intake made.Has the manners of a dual plane runs like a sinlge.Rocky
Chrysler Firepower
[Re: B5 Bee]
#633290
03/08/10 07:46 PM
03/08/10 07:46 PM
mopar4ya
western PA
Thanks guys. My mistake on the head casting numbers, they are the 516's. He had these heads gone through a couple of years ago, and used them on a 383. They don't have a lot of run time. It's his engine and $$, so I can only make suggestions. What can a 452 or 906 casting be milled to as far as CC's and still be safe? Could he get 10:5 compression or more with one of these castings using the pistons he has? Dan ![](/ubbthreads/images/graemlins/beer.gif)
[Re: forphorty]
#633294
03/08/10 10:13 PM
03/08/10 10:13 PM
mopar4ya
western PA
I have a feeling your friend wants 11:1 compression so he can say he has eleven to one compression. Sounds more badazz than saying you have ten and a half to one. I bet the difference between 10.5 and 11.0 wouldn't be more than 5 hp on that engine. Not enough to justify mixing fuels, IMO.
I don't think he is the type that would brag about anything. I'm thinking maybe he has heard others claiming to be running this compression and how good there engine runs. Truth be known, not many guy's truly have a clue to what their REAL compression ratio is. I'll bet most that do the bragging have about 1 to 1-1/2 points less compression than they THINK they have. He's a good guy and I just want to see him get the most out of what he has or can afford.
Thanks! Dan ![](/ubbthreads/images/graemlins/beer.gif)
[Re: mopar4ya]
#633295
03/09/10 01:46 AM
03/09/10 01:46 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I can tell you my 906 iron headed 440 in my 63 came out to 10.0 comp after I used the right head gasket with the 906 heads. I run 38 total timing all in by 2000 rpm and I use the MP .557 cam. It runs great on 92 pump with no ping at all. I do use the quench pad pistons from KB as I got the quench on all cylinders in the .040 to .045 area. But it is nice to drive to the track and stop along the way to get pump gas in the 2 to 3 dollar range and not have to get race gas at the track for 8 bucks or so ! I figured if I ran 11.5 or 12.0 comp it would only be worth a tenth or two and its not worth it to me as I will give up a tenth or two to save money as I never have enough money now as it is. ![](/ubbthreads/images/graemlins/biggrin.gif) Ron
