Re: Best Choice On A Intake ?? [Re: forphorty] #633294
03/08/10 10:13 PM
03/08/10 10:13 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
I have a feeling your friend wants 11:1 compression so he can say he has eleven to one compression. Sounds more badazz than saying you have ten and a half to one. I bet the difference between 10.5 and 11.0 wouldn't be more than 5 hp on that engine. Not enough to justify mixing fuels, IMO.
I don't think he is the type that would brag about anything. I'm thinking maybe he has heard others claiming to be running this compression and how good there engine runs. Truth be known, not many guy's truly have a clue to what their REAL compression ratio is. I'll bet most that do the bragging have about 1 to 1-1/2 points less compression than they THINK they have.
He's a good guy and I just want to see him get the most out of what he has or can afford.
Thanks!
Dan
Re: Best Choice On A Intake ?? [Re: mopar4ya] #633295
03/09/10 01:46 AM
03/09/10 01:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I can tell you my 906 iron headed 440 in my 63 came out to 10.0 comp after I used the right head gasket with the 906 heads. I run 38 total timing all in by 2000 rpm and I use the MP .557 cam. It runs great on 92 pump with no ping at all. I do use the quench pad pistons from KB as I got the quench on all cylinders in the .040 to .045 area. But it is nice to drive to the track and stop along the way to get pump gas in the 2 to 3 dollar range and not have to get race gas at the track for 8 bucks or so ! I figured if I ran 11.5 or 12.0 comp it would only be worth a tenth or two and its not worth it to me as I will give up a tenth or two to save money as I never have enough money now as it is. Ron
Re: Best Choice On A Intake ?? [Re: 383man] #633296
03/09/10 03:25 PM
03/09/10 03:25 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
So the intake manifolds suggested are good. In addition, Id use 383mans cam MP 557 solid. If only hyd cam is possible, get on the phone with Comp or others here to match a good cam for you. That 509 is a big cam for those small heads. It requires a high stall and gears to really work. There are others out there that will be a better match to your combo as posted.
