727stuff sunshell-front drums-and Input shaft #632962
03/07/10 03:47 PM
03/07/10 03:47 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Ok here is a pic of my $10.00 lighten sun shell..Hey it can't hurt
And a pic of the 5 clutch front drum for who might want to see it. stock one on the left-5 clutch on the right see how high the snap ring groove is.
At the last pic is a input shaft. Look at oil feed hole where I got in mark in red. I have 4 input shafts here.This is the only one with that hole.And this is the shaft I had in the car. I want to use one of the other shafts..But I not sure what this feed hole is. Anyone know ?
Re: 727stuff sunshell-front drums-and Input shaft [Re: VernMotor] #632963
03/07/10 04:50 PM
03/07/10 04:50 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
It's a lubrication feed for the input shaft bushing. Oil return from the cooler is fed into the mainshaft and through a drilled passage in the mainshaft to the small bushing in the rear drum and then through another passage to this hole to feed the bushing for the input shaft.
Re: 727stuff sunshell-front drums-and Input shaft [Re: PC-CHARGER] #632964
03/07/10 04:54 PM
03/07/10 04:54 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
You gonna' have that tranny done by opening day????
Re: 727stuff sunshell-front drums-and Input shaft [Re: PC-CHARGER] #632965
03/07/10 05:13 PM
03/07/10 05:13 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
OK so is there a year change here ..Why do the other shafts do not have it ?..Is it OK to use a shaft that does not have this hole ? OK I see that hole is in the other shaft but not on the bearing surface but below it. Thanks
Bill there is still snow on the ground I got time
Re: 727stuff sunshell-front drums-and Input shaft [Re: VernMotor] #632966
03/07/10 05:24 PM
03/07/10 05:24 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Not sure on the year of the changes but the lube hole did change location slightly. The other style that does not have the lube hole where you have circled has it located behind the journal area. Still fed from the same hole in the back of the shaft though. The lockup shafts are different yet again.
Re: 727stuff sunshell-front drums-and Input shaft [Re: VernMotor] #632967
03/07/10 05:34 PM
03/07/10 05:34 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
As long as your spline count is the same, they should interchange. Earlier models had fewer splines and a slightly smaller shaft size. As far as the lubrication hole location, I can't say for sure which is better but my preference would be the one with the hole centered in the bushing.
Re: 727stuff sunshell-front drums-and Input shaft [Re: PC-CHARGER] #632968
03/07/10 05:58 PM
03/07/10 05:58 PM
Northwest, Ohio
360DOUG Offline
360DOUG  Offline
Northwest, Ohio
In the picture of your input shaft is that a sealing ring groove on the retainer below the red square? If so it is a 1978 and up input shaft.
Re: 727stuff sunshell-front drums-and Input shaft [Re: PC-CHARGER] #632969
03/07/10 06:01 PM
03/07/10 06:01 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Thanks..one of them you learn something new everyday !!
Re: 727stuff sunshell-front drums-and Input shaft [Re: 360DOUG] #632970
03/07/10 06:06 PM
03/07/10 06:06 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Well I needed to hold still and take a better picture LOL but no it is not.. I know what you are talking about...thanks for looking
Re: 727stuff sunshell-front drums-and Input shaft [Re: VernMotor] #632971
03/07/10 06:18 PM
03/07/10 06:18 PM
Northwest, Ohio
360DOUG Offline
360DOUG  Offline
Northwest, Ohio
Good Luck with the trans build. Getting ready to do the same here. I always take my time and double check everything. As you said there is still snow on the ground.
Re: 727stuff sunshell-front drums-and Input shaft [Re: 360DOUG] #632972
03/07/10 07:00 PM
03/07/10 07:00 PM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Drum on left is a narrow bush and the other is a wide. If changing over, make sure rest of components match
Good Luck
Re: 727stuff sunshell-front drums-and Input shaft [Re: TheBlackCar] #632973
03/07/10 07:09 PM
03/07/10 07:09 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Good Luck
Yes it is.. I was just using it show..I need to thow it away..I never use it !
Re: 727stuff sunshell-front drums-and Input shaft [Re: VernMotor] #632974
03/07/10 09:08 PM
03/07/10 09:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The input shaft with the bushing lube hole is pre-'74, in '74 they changed the lube circuit so that the bushing is lubed by the output shaft; at the same time they eliminated the front clutch lube hole in the support, big mistake IMHO.
