Bearing clearance ??? #632859
03/07/10 12:17 PM
03/07/10 12:17 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
What is the recomended rod and main bearing clearances on a 440 stock crank, after market H-beam rods. Also what are the acceptable min/max to the recomended clearances? This a drag race only engine, no no2, no blower.
Thanks, Brian
Re: Bearing clearance ??? [Re: '72CudaRacer] #632860
03/07/10 12:34 PM
03/07/10 12:34 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
.001 per 1" of Journal Size. If you deviate, MORE is ALWAYS better.
SRT DEMON ONE SEAT
Re: Bearing clearance ??? [Re: '72CudaRacer] #632861
03/07/10 01:05 PM
03/07/10 01:05 PM
NC
440Jim Offline
440Jim  Offline
NC
This is really a builder preference item, and application specific. There is no hard number +/-, but most race builder's want their number within 0.0003"
A starting point would be 0.0023" on the rods, and 0.0030" on the mains. Many race applications/builders want more.
Re: Bearing clearance ??? [Re: 440Jim] #632862
03/07/10 02:09 PM
03/07/10 02:09 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
mine is set at .0025 on the mains and .0023-.0025 on the rods and going strong.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Bearing clearance ??? [Re: '72CudaRacer] #632863
03/07/10 02:22 PM
03/07/10 02:22 PM
Carson City, NV
440sourcedotcom Offline
Carson City, NV
In an absolutely ideal world, (for most applications) you'd want .0025 on the rods and .003 on the mains. Realistically, with real world production tolerances, it's great if you can get between .002-.003 on the rods and .0025-.0035 on the mains.
