1997 DODGE CUMMINS FUEL PROBLEMS #62967
05/24/08 08:22 PM
05/24/08 08:22 PM
Big Wonderful Wyoming!
toomanymopars Offline OP
I have a 97 Cummins that sat for a year with the trans. out. Engine ran fine when I parked the truck. (Truck has 297,000 miles).
Now that we got the trans. rebuilt, I can't get it to run. I cracked the injector lines and no fuel. I can push the primer button on the primary pump, and get nothing, but when I crank it over with the line loose coming from the filter, I get fuel.
Any ideas?
thanks!
Re: 1997 DODGE CUMMINS FUEL PROBLEMS [Re: toomanymopars] #62968
05/24/08 08:31 PM
05/24/08 08:31 PM
Try pulling the fuel filter out and filling it up with fuel put it back on then try it .
Re: 1997 DODGE CUMMINS FUEL PROBLEMS #62969
05/24/08 09:51 PM
05/24/08 09:51 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
fuel shutoff solonid ,might be bad,power wire from batt to solonid relay or relay.lift up on solonid with key on then try starting.
