I have a 97 Cummins that sat for a year with the trans. out. Engine ran fine when I parked the truck. (Truck has 297,000 miles).
Now that we got the trans. rebuilt, I can't get it to run. I cracked the injector lines and no fuel. I can push the primer button on the primary pump, and get nothing, but when I crank it over with the line loose coming from the filter, I get fuel.
Any ideas?
thanks!
