904/998, what's the best combination of these parts??
#628246
03/01/10 09:26 PM
03/01/10 09:26 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
OK I have a 998 with the low gears but it also has a very good non-locking 998 spline converter that footbrakes right at 3100 behind the 341" LA motor in the Rocky. I also have a good rebuildable 904 core I just picked up last night and a T/A shift kit....(I don't want to put a full race VB in this thing just yet....not until I get a handle on how this 85" wheelbase toy goes down the track.....with the stock 318 it went straight as a string, but now I'm doubling the hp and the launch RPM speed. Since i already have a good (great) converter, The main achilles heel (I'm told) of the 998 is really the high gear spring pack is too weak and tends to slip in high gear for racing....but I'm also told this could simply be swapped for a 904 drum/spring pack and would work well for a maybe 450 horse 2800 pound "thing" with 4.56 gears. The other option is obvious....swap the low gear set into the 904 but that leaves me with the dillema of finding another ($$$) converter to replace the one that happens to work very well. Based on what I've laid-out and given the motor car we're dealing with, what is the best use of the components I have? I'm Thinking both the Low gearset and the 998 input shaft/vert can be swapped into a 904 (which would really be perfect) but I may be off base..... I just want to build it with the best combo of parts that I have on hand and go rounds reliably....to be honest I probably don't NEED the deep gearset with this car but since I already have them... I've built several trannies but I've never really stayed up on the 'what goes with what' parts combinations that are possible.....I know some of you guys know TF trannies inside and out, so I'm all ears I'd love to ship it off to one of our Moparts guys on the site here...but the Varners (Bill Sr. and Junior) here in Charlotte are very well-known/respected as a TF gurus and a long time (3 generations) racing family....and I haven't blown up anything he's built for me in over 20 years I've known him.....and that's been quite a few Torqueflights
Re: 904/998, what's the best combination of these parts??
[Re: dvw]
#628249
03/02/10 11:54 AM
03/02/10 11:54 AM
Streetwize
Weddington, N.C.
dvw, Thanks and that's EXACTLY why I"m posting up....I talked to Johnny and basically If I can swap the 998 input shaft (so i can reuse the same non lock-up converter) and gears into the 904 I'm good. Johnny did recommend going to the 727 style high gear spring pack which will be a great upgrade, especially if I wind up spraying this thing someday. I'm pretty saavy on the stuff on the front side of the flexplate but I'm not afraid to ask what I don't know enough about. The easiest thing to do would be just build the 904 and get a new vert but like i said this vert and low first gear work so well I'd hate to change anything about it.
[Re: Streetwize]
#628250
03/02/10 12:29 PM
03/02/10 12:29 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
The hydraulic application of the piston locks the clutch pack up.....not the spring.
The spring is there to release it when not in reverse or high gear.
The problem with the single coil spring presents itself in 1st gear at high RPM. The spring unwinds itself and loads the high gear piston, which subsequently burns up the clutches. A kit from A&A replaces the single spring with a multi-spring return much like the 727s.
It also provides a cleaner release if using a trans-brake.
[Re: dizuster]
#628252
03/02/10 12:35 PM
03/02/10 12:35 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Whoops, ST/ beat me to it!
By the way, the input shaft splines are not any different between the two converters. However depending on the year of the 998, it might have a different Pump snout drive...
The input shaft has to go with the pump (depends on the # of sealing rings) The pump MAY have to go with the high gear drum (depending on clearance to the pump, and large diameter sealing ring differences), the high gear drum MAY need to go with the sun shell (two different diameters), etc...
Be very careful.
[Re: dizuster]
#628253
03/02/10 02:02 PM
03/02/10 02:02 PM
Streetwize
Weddington, N.C.
I know when I got the converter, the 998 has 1 more (or 1 less...I Can't remember) spline on the snout. So is there anything else internally in the 998 that would prevent it from performing the same as the 904? What else is different? The non locking/lock-up splined Vert is the main reason I want to keep the snout in whichever trans, It's a 9 1/2" unit that hooks really sweet. Yeah, that's a much better explanation of the Spring pack Makes more sense now. I just want to go rounds and not blow it up.
