Chaning Center Section - Housing and yolk interchange? #626159
02/27/10 09:24 PM
02/27/10 09:24 PM
440charger70 Offline OP
super street
super street
I found a good deal on a local center section for sale. I currently have a 489 housing with a big yolk and will be changing to a 741 housing that currently has a small yolk. My question is:
1.) Will the 741 housing bolt in place of the 489 housing or will I need extra parts?
2.) Will the yolk from the 489 housing bolt right onto the 741 housing in place of the small yolk?
Thanks!
Re: Chaning Center Section - Housing and yolk interchange? [Re: 440charger70] #626160
02/27/10 09:30 PM
02/27/10 09:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yes, center sections will swap, you will need a gasket though. Not sure about yokes though, IIRC, the diff is spline count for yokes, not housing number.
If all else fails, they make a conversion U joint to hook a small joint D/D to a big joint yoke, or vice versa.
Don't be the exception.
Re: Chaning Center Section - Housing and yolk interchange? [Re: 440charger70] #626161
02/27/10 09:32 PM
02/27/10 09:32 PM
salem, oregon. usa
E
elmor Offline
elmor  Offline
E
salem, oregon. usa
The center section will interchange with what you have. I am not certain on the yoke, but they make U-joints that have both sizes on them. You can use the larger end in your driveline, and the smaller side to fit your yoke.
Re: Chaning Center Section - Housing and yolk interchange? [Re: 440charger70] #626162
02/28/10 05:55 PM
02/28/10 05:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Both the 489 and the 741 came with either 10-spline pinions or 29-spline pinions, the 10-spline will have a 1 1/8" hex nut, the 29-spline will have a 1 1/4" nut.
