Factory Kickdown Linkage and Performer RPM #624628
02/25/10 11:46 PM
02/25/10 11:46 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
Will factory kickdown linkage work with a Performer RPM intake? The car is a '67 Satellite 440/727. I don't have the stock kickdown linkage around to try so that's why I ask so I know if I will have to order some kind of cable kickdown setup. Thanks!
Re: Factory Kickdown Linkage and Performer RPM [Re: 67Satty] #624629
02/26/10 12:58 AM
02/26/10 12:58 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
With a little fab-work, you can make it happen. Here's mine on a low-deck. I wanted a stock look (and I'm sorta cheap, so I tend to work with what I've got). This started as a stock 2-bbl setup. I extended the height of the stock throttle cable bracket, and bent the top kick-down rod to fit the extra ht. Then had to add threaded rod onto the end of the original rod to make it reach. Seems to work perfectly.
Re: Factory Kickdown Linkage and Performer RPM [Re: 67Satty] #624630
02/26/10 10:16 AM
02/26/10 10:16 AM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
There is no such animal as kick down linkage.Throttle press linkage yes,kick down linkage,no.
Re: Factory Kickdown Linkage and Performer RPM [Re: I go fast] #624631
02/26/10 11:04 AM
02/26/10 11:04 AM
Of course, if you disconnect the throttle pressure linkage, the transmission will no longer "kick down."
Gensrud's solution is the same one I've done several times. Modify the stock pieces to get the lengths and angles right; helps if you have a welder.
Re: Factory Kickdown Linkage and Performer RPM #624632
02/26/10 03:22 PM
02/26/10 03:22 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Rich H.
Esse Quam Videri
Re: Factory Kickdown Linkage and Performer RPM [Re: ZIPPY] #624633
02/26/10 04:26 PM
02/26/10 04:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
"Of course, if you disconnect the throttle pressure linkage, the transmission will no longer "kick down."
Right, but it will fry becasuse of low pressure.
Re: Factory Kickdown Linkage and Performer RPM [Re: stumpy] #624634
02/26/10 05:29 PM
02/26/10 05:29 PM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
And it won't down shift either!
Re: Factory Kickdown Linkage and Performer RPM [Re: I go fast] #624635
02/26/10 05:38 PM
02/26/10 05:38 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Let's play nice children. The stock linkage will work. You need the 3 peice linkage. It won't work with the single rod version. I have it on mine and it works perfect and looks stock.
Re: Factory Kickdown Linkage and Performer RPM [Re: Dougsmopars] #624636
02/26/10 06:21 PM
02/26/10 06:21 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The one piece rod will work with most anything if you lengthen it and use the correct throttle pressure lever.
Re: Factory Kickdown Linkage and Performer RPM [Re: 62maxwgn] #624637
02/26/10 09:12 PM
02/26/10 09:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Firewall clearance dictates whether or not the one-piece rod will work.
Re: Factory Kickdown Linkage and Performer RPM [Re: John_Kunkel] #624638
02/26/10 09:52 PM
02/26/10 09:52 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
I run a 3 piece with my performer RPM. All I did was bend the rod attached to the carb and twist the adjustment nearly all the way out. I maybe have 3 threads left go but I get the right clearance/adjustment.
Re: Factory Kickdown Linkage and Performer RPM [Re: I go fast] #624639
02/26/10 09:54 PM
02/26/10 09:54 PM
If you come to a stop it will . . . .
Re: Factory Kickdown Linkage and Performer RPM [Re: ZIPPY] #624640
02/27/10 12:17 AM
02/27/10 12:17 AM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
http://arengineering.com/throttlebracket/Tbracket/tbracketframe.html
This looks like a winner. And they call it kickdown linkage too.
Re: Factory Kickdown Linkage and Performer RPM [Re: 67Satty] #624641
02/27/10 01:16 AM
02/27/10 01:16 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Ever see the term "kickdown linkage" in a FSM?
Re: Factory Kickdown Linkage and Performer RPM [Re: John_Kunkel] #624642
02/27/10 12:35 PM
02/27/10 12:35 PM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
Not Mopar FSM.
It's to late and there are to many to retrain.
Re: Factory Kickdown Linkage and Performer RPM [Re: demonH1B] #624643
02/27/10 12:40 PM
02/27/10 12:40 PM
Dougsmopars Offline
Dougsmopars  Offline
Who cares what you want to call it? We all know what he means and wasting time with grammer doesn't answer his question.
Re: Factory Kickdown Linkage and Performer RPM [Re: Dougsmopars] #624644
02/27/10 12:47 PM
02/27/10 12:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Because it has a correct name and it should be used. You don't call an airplane an engine powered bird.
Re: Factory Kickdown Linkage and Performer RPM [Re: Dougsmopars] #624645
02/27/10 01:12 PM
02/27/10 01:12 PM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
Because we still have people that think the "linkage" isn't
necessary if you manually downshift (kickdown).
There were transmissions built with "kickdown
linkage" and other shifts were controlled by a vacuum modulator, but not by Chrysler.
Re: Factory Kickdown Linkage and Performer RPM [Re: demonH1B] #624646
02/27/10 01:28 PM
02/27/10 01:28 PM
Dougsmopars Offline
Dougsmopars  Offline
Better call Herb's and let them know all there linkage listings are incorrect. 440 4 BBL 3 PC KICKDOWN LINKAGE EARLY STYLE Details
440 4 BBL 3 PIECE KICKDOWN LINKAGE EARLY STYLE. FITS 66-68 "B" BODY W/ORIGINAL 3 PIECE STYLE KICKDOWN LINKAGE. KIT INCLUDES LINKAGE W/UPPER & LOWER BELLCRANKS, TRANSMISSION THROTTLE LEVER, THROTTLE CABLE MOUNTING BRACKET, RETURN SPRING & HARDWARE.
Price: $350.00
Re: Factory Kickdown Linkage and Performer RPM [Re: demonH1B] #624647
02/27/10 01:41 PM
02/27/10 01:41 PM
Cookeville
Chilort Offline
Chilort  Offline
Cookeville
Does the throttle pressure linkage also operate the kickdown function? Are there kickdown valves, kickdown servos, and is the front band also called the kickdown band in the FSM?
The answer to these questions is Yes. If the throttle pressure rod did not have anything to do with the kickdown function then maybe then it would be a misnomer.
In short, this is nothing more than formal semantics. There is nothing lexically or conceptually wrong with calling the throttle pressure linkage/rod the kickdown rod. The important thing is that we all know what you mean.
My
