When is a steering column considered collapsed? #624570
02/25/10 10:50 PM
02/25/10 10:50 PM
Woodbridge,CA
NAS Backyard Offline OP
Woodbridge,CA
I'm replacing my steering box in my 69RR and I was reading the instructions (imagine that) It says to remove the column to avoid damage to the energy absorbing steering column. I got the gear box out without doing that. I'm pretty sure this part is suppose to slide back and forth to allow removal but I'm just trying to clarify. I "rebuilt" this part with a kit I bought from one of the vendors.It consisted of a pin,spring, some half round discs and a rubber boot. Everything is tight. I was thinking the webbed section under the dash was the collapsable part of the colunm. I was just going to install the gear, line everything up straight, slide the sleeve onto the shaft and put the pin in it. Any input on this? Thanks
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: When is a steering column considered collapsed? [Re: NAS Backyard] #624571
02/26/10 12:52 AM
02/26/10 12:52 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The shaft that goes into the coupler has a shear/ slip joint inside the column, that if bumped or in an accident will slide instead of impaling the driver with the column shaft, there is also a wire grater section of the jacket that can collapse to allow energy to be absorbed..
There should be no sliding of the shaft into the column on a good column, if the shaft slips easily into the column the safety capsule is broken and needs repair..
Here is a photo of the slip joint..
Re: When is a steering column considered collapsed? [Re: sthemi] #624572
02/26/10 02:29 AM
02/26/10 02:29 AM
Woodbridge,CA
Woodbridge,CA
OK, Thanks! Looks like mine is good to go. I got everything in and hooked up but forgot to remove the hose fitting on the old gear box so I had to rob one off the Challenger. Still need to order a dipstick tube.
