Page 1 of 3 1 2 3
Why not use 727 like a glide #624097
02/25/10 03:35 PM
02/25/10 03:35 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Was running some numbers around and was wondering why not use the first two gears on a 727 like a glide then third will be overdrive.
The 727
1st 2.45
2nd 1.45
so 2.45/1.45=1.69
a glide is 1.76 first to second ratio
I understand the extra drag on internal components and needed to get the convertor set up right.
[image]https://board.moparts.org/ubbthreads/upload2/5829790-Glidevs727.tif[/image]
Re: Why not use 727 like a glide [Re: Dart451] #624098
02/25/10 03:46 PM
02/25/10 03:46 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
The 727
1st 2.45
2nd 1.45
so 2.45/1.45=1.69
The whole idea of going to a glide is to get away from the low 1st gear.
Im not following you on the OD thing.
The only two gears between them that are actually the same is the ones your not wanting to use LOL..
High and 3rd are the same.
Both are a 1:1
Re: Why not use 727 like a glide [Re: Bob_Coomer] #624099
02/25/10 03:51 PM
02/25/10 03:51 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
I want to use a 3.23 or 2.76 rear gear and run 1/4 using first and second only. So I will finish at the strip in second.
Re: Why not use 727 like a glide [Re: Dart451] #624100
02/25/10 03:59 PM
02/25/10 03:59 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
THERE 'ya go ! ... ... been doin' THIS furr years !
Re: Why not use 727 like a glide [Re: dOoC] #624101
02/25/10 04:35 PM
02/25/10 04:35 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
Joe at Tranzact sells a 2 speed 727. This would be much cheaper then converting over to a PG, if your car already has a 727
Re: Why not use 727 like a glide [Re: Big B] #624102
02/25/10 04:46 PM
02/25/10 04:46 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Not about wanting a two speed as wanting to drive the car down the highway. I already have a well built 727, so if the convertor is redone, and change the rear gears it would be alot cheaper then a overdrive.
Looking for why this would be a bad idea?
Re: Why not use 727 like a glide [Re: Dart451] #624103
02/25/10 05:05 PM
02/25/10 05:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Why not?? It will work.
Re: Why not use 727 like a glide [Re: Dodgem] #624104
02/25/10 05:16 PM
02/25/10 05:16 PM
organ
maximum entropy Offline
organ
why not? with the right converter, you prolly wouldn't lose much. i do it in the eighth.
Re: Why not use 727 like a glide [Re: maximum entropy] #624105
02/25/10 07:39 PM
02/25/10 07:39 PM
100%.......Everyone wants an overdrive or Gear Vendors , but a 727 with a decent converter (3,800 and up) is JUST as driveable as an OD and will run VERY well at the strip.....been there, done that MANY times.......
Wayne
Re: Why not use 727 like a glide #624106
02/25/10 08:54 PM
02/25/10 08:54 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Never seen much posted about it, so figured I was missing something.
Think I will start looking for a new rear gear.
Re: Why not use 727 like a glide [Re: Dart451] #624107
02/25/10 09:25 PM
02/25/10 09:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Back in the early seventies some nitro funny cars used 1st and 2nd gear in the 727 with 2.76 rear end gears. Top gear was close to the 3.91's everybody was running then.
Re: Why not use 727 like a glide [Re: John_Kunkel] #624108
02/26/10 11:40 AM
02/26/10 11:40 AM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
I would think the glide would have a lot less drag and would weigh less.
so in a light car the glide would be better at the strip.
I still have a heavy car so I need the lower first gear of the 727.
I run a 3.89 gear and 28 inch tall tires
been thinking about going with 3.55's in a attempt to use the torque of the nitrous motor..
Re: Why not use 727 like a glide [Re: RADAMX] #624109
02/26/10 12:13 PM
02/26/10 12:13 PM
PA
moparacer Offline
moparacer  Offline
PA
It wont be "like a glide" because you will be using the planetary in 1st and 2nd gear.
Wont have the true 1:1 ratio.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Why not use 727 like a glide [Re: moparacer] #624110
02/26/10 12:20 PM
02/26/10 12:20 PM
organ
organ
i don't think the op is worried about absolute maximum efficiency, and neither am i. these are street cars, and after a long weekend of racing, NOTHING is finer than hitting the highway home and snicking that baby into "top cog". too bad i have a dana 60, or i'd put 2.71's in it!
Re: Why not use 727 like a glide [Re: maximum entropy] #624111
02/26/10 01:03 PM
02/26/10 01:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
One problem would be that you wouldnt have a trans
brake.... if you use one
Re: Why not use 727 like a glide [Re: MR_P_BODY] #624112
02/26/10 03:29 PM
02/26/10 03:29 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
I already have a trans brake why couldn't i use it?
Re: Why not use 727 like a glide [Re: Dart451] #624113
02/26/10 03:31 PM
02/26/10 03:31 PM
organ
organ
i would.
Re: Why not use 727 like a glide [Re: maximum entropy] #624114
02/26/10 04:20 PM
02/26/10 04:20 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Thats what i dont under stand with the OP... neither the the 727 or the PG has is OverDriven in 3rd? Were is the OD you guys keep talking about? They both have a final drive a 1:1
In this case a A518 would be optional..
Re: Why not use 727 like a glide [Re: Bob_Coomer] #624115
02/26/10 04:39 PM
02/26/10 04:39 PM
organ
organ
no, it would not "actually" be overdrive, but the overall ratio would be as if it were overdriven, capice? yer making a very simple concept into something complicated.
Re: Why not use 727 like a glide [Re: Dart451] #624116
02/26/10 04:48 PM
02/26/10 04:48 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
when i first got into racing with my 'cuda, with the 3.23 gears & tweaked stock converter, i'd be changing into 3rd as i crossed the stripe. i think i ran 275x60 quicktimes with that combo. isn't this where you want to be?
Page 1 of 3 1 2 3
