Why not use 727 like a glide
#624097
02/25/10 03:35 PM
02/25/10 03:35 PM
Posts: 667 IL
Dart451
IL
Was running some numbers around and was wondering why not use the first two gears on a 727 like a glide then third will be overdrive.
The 727 1st 2.45 2nd 1.45 so 2.45/1.45=1.69 a glide is 1.76 first to second ratio
I understand the extra drag on internal components and needed to get the convertor set up right.
[image]https://board.moparts.org/ubbthreads/upload2/5829790-Glidevs727.tif[/image]
Re: Why not use 727 like a glide
[Re: Dart451]
#624100
02/25/10 03:59 PM
02/25/10 03:59 PM
Posts: 30,459 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
I want to use a 3.23 or 2.76 rear gear and run 1/4 using first and second only. So I will finish at the strip in second.
THERE 'ya go ! ... ... been doin' THIS furr years !
[Re: Dodgem]
#624104
02/25/10 05:16 PM
02/25/10 05:16 PM
Posts: 5,080 organ
maximum entropy
organ
why not? with the right converter, you prolly wouldn't lose much. i do it in the eighth.
[Re: maximum entropy]
#624105
02/25/10 07:39 PM
02/25/10 07:39 PM
100%.......Everyone wants an overdrive or Gear Vendors , but a 727 with a decent converter (3,800 and up) is JUST as driveable as an OD and will run VERY well at the strip.....been there, done that MANY times.......
Wayne
[Re: Dart451]
#624107
02/25/10 09:25 PM
02/25/10 09:25 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Back in the early seventies some nitro funny cars used 1st and 2nd gear in the 727 with 2.76 rear end gears. Top gear was close to the 3.91's everybody was running then.
[Re: RADAMX]
#624109
02/26/10 12:13 PM
02/26/10 12:13 PM
Posts: 2,515 PA
moparacer
PA
It wont be "like a glide" because you will be using the planetary in 1st and 2nd gear.
Wont have the true 1:1 ratio.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#624110
02/26/10 12:20 PM
02/26/10 12:20 PM
Posts: 5,080 organ
maximum entropy
organ
i don't think the op is worried about absolute maximum efficiency, and neither am i. these are street cars, and after a long weekend of racing, NOTHING is finer than hitting the highway home and snicking that baby into "top cog". too bad i have a dana 60, or i'd put 2.71's in it!
[Re: Dart451]
#624116
02/26/10 04:48 PM
02/26/10 04:48 PM
Posts: 4,647 aotearoa
rebel
aotearoa
when i first got into racing with my 'cuda, with the 3.23 gears & tweaked stock converter, i'd be changing into 3rd as i crossed the stripe. i think i ran 275x60 quicktimes with that combo. isn't this where you want to be?
