Re: B&M Supercharger
[Re: Mr.Yuck]
#621762
10/21/12 02:20 PM
10/21/12 02:20 PM
Posts: 3,868 N.E. Ohio
6bblFLASH
N.E. Ohio
Yes they`ve reground some of them. the 484 and 509 are now 114 c/l.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#621763
10/23/12 03:13 AM
10/23/12 03:13 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
some of yall that have the 174/177 blowers, can you please show pics of the crank pulley? or adapter if there is one?
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: 6bblFLASH]
#621765
11/25/12 12:19 PM
11/25/12 12:19 PM
mopardude318
Gilroy,CA.
I found an original 162ci B&M blower kit for small block mopar, new never used off of craigslist. I purchased it, I should have it by tuesday...I'll update with pics once I get it.
[Re: TheOtherDodge]
#621771
11/30/12 07:55 PM
11/30/12 07:55 PM
mopardude318
Gilroy,CA.
Look into a Chevy HHR fan. You can get one from Rockauto.com for about $60 shipped. It works like a champ and is low profile.
http://www.customdakotas.com/forums/v8-performance/11377-hhr-fan-installed.html
http://www.rockauto.com/catalog/raframec...1115394-3378837
I also looked into that, and the fan from a ford taurus. Unfortunately, they are both too big to fit my radiator. I think I am forced to stay the same size as my core on my Afco radiator.
I'm at 5 & 1/2" from the front of the balancer to the front of the blower drive pulley.
I thought about reducing the blower pulley's outside diameter so it fits inside the crank pulley...And that COULD in fact work....I think...
But before I start modifying this stuff, I'm gonna try a couple things first. I pulled my mechanical fan off, and started taking measurements to build a shroud, to use with electrics fans. Either ONE single large fan, or TWO smaller fans is what I have to work with. I have an Afco radiator that has a core width of 20" and core height of 17.5". So thats what the shroud needs to be to. From what I've read it's recommended to shroud the whole surface of the core for use of electric fans.
3 1/4" from the water pump pulley bolts to the radiator.
2 5/8" blower pulley to radiator. Really tight, I know. :/
proto type shroud: LOL
I'll need some pretty thin electric fans, But can get away with thicker ones if they are off set.
I will try to find some fans that fit my needs. I'm probably making this part harder on myself. I should bolt on the shorter snout, cut down the blower pulley and spacer, and be done with it. LOL
[Re: CW25]
#621775
12/25/12 08:44 PM
12/25/12 08:44 PM
mopardude318
Gilroy,CA.
Been away for a while, been slowly gathering other parts needed for this swap. I am in the market for a carburetor. What would you guys recommend? I have my eye on the Holley line of supercharger carburetors, like the 750 mechanical secondary manual choke version. http://www.summitracing.com/parts/hly-0-80573sThere is also one with no choke, and a few more additional features...like "screw-in air bleeds for added tuning, a notched float, and jet extensions to prevent fuel starvation. Other features include a 4-corner idle system, and dual 30cc or 50cc accelerator pumps" http://www.summitracing.com/parts/hly-0-80576sHow would the above carbs work with an automatic? I Haven't found a supercharger specific carb with vacuum secondaries... Any thoughts...anyone?
[Re: DusterDave]
#621778
04/23/13 08:50 PM
04/23/13 08:50 PM
mopardude318
Gilroy,CA.
Small update. I decided it would be better to use a 1" shorter blower snout. Here it is installed on the blower. That way I could use the mechanical fan, now I have to machine 1" off the blower pulley spacer. :blob: After months of saving little by little, and a 10% off coupon from summit, I finally was able to purchase the recommended Felpro 1008 head gaskets, a Holley 750 supercharger carb, and the MSD 6BTM ignition box. Next big thing on the list is the Water/Methanol injection system. This, combined with the boost retard ignition should dramatically reduce the chances of detonation. Helping the engine along to surviving. :happy8:
