Engine run-in stands #621193
02/22/10 08:15 PM
02/22/10 08:15 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Looking for something to do and have decided to build a run-in stand. I have a framework pretty much done but would like to see some others to compare with it before continuing and to pick up any tips/pointers. Also, do I need to include a ballast in the ignition??
Thanks in advance!
Re: Engine run-in stands [Re: slowpoke] #621194
02/22/10 08:23 PM
02/22/10 08:23 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Here's a video of ours...we have less than 100 bucks in it since we had most everything for it already lying around (starter, bellhousing, ignition stuff)
Yeah, we used a factory Chrysler ignition with the ballast resistor. We also added a tach after we shot the video.
http://www.youtube.com/watch?v=b_W2PLpVtJU
Re: Engine run-in stands [Re: dustergirl340] #621195
02/22/10 08:41 PM
02/22/10 08:41 PM
united states
badrap Offline
badrap  Offline
united states
i am working on making one now also. got a 5.7 hemi and i want to make sure i have everything right before i pull my car apart to put it in.so i will be watching too
Re: Engine run-in stands [Re: slowpoke] #621196
02/22/10 08:48 PM
02/22/10 08:48 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Here's a shot of a friends stand he built that is adjustable for different engines. Shown here with my engine setup but it normally has a regular Mopar electronic ignition setup.
Re: Engine run-in stands [Re: PC-CHARGER] #621197
02/22/10 10:41 PM
02/22/10 10:41 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
PC-Charger, that's a great setup and answers my next question about using an auto trans. Dustergirl340, your set up looks about what mine is heading toward and seems to work great which makes me feel better about my design (watch out for that fan blade!!) Thanks for the responses.
Anyone else???
Re: Engine run-in stands [Re: slowpoke] #621198
02/22/10 10:55 PM
02/22/10 10:55 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Some pics of mine. Pardon the Chevs. I make money building Chevs to buy MOPAR stuff for myself. Some pics are while building, others in use. I used an 'over seas' shipping crate for the basis. Cut down build time not having to fab whole frame work.
If you like drag racing, support your local track.
Re: Engine run-in stands [Re: CHAPPER] #621199
02/22/10 10:56 PM
02/22/10 10:56 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
more
Re: Engine run-in stands [Re: CHAPPER] #621200
02/22/10 10:57 PM
02/22/10 10:57 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
in process of building
Re: Engine run-in stands [Re: CHAPPER] #621201
02/22/10 10:58 PM
02/22/10 10:58 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
'nuther
Re: Engine run-in stands [Re: CHAPPER] #621202
02/22/10 11:02 PM
02/22/10 11:02 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Chapper, do you have a ground from the battery to the stand itself, to the engine or both??
Re: Engine run-in stands [Re: slowpoke] #621203
02/22/10 11:03 PM
02/22/10 11:03 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Both
Re: Engine run-in stands [Re: CHAPPER] #621204
02/22/10 11:05 PM
02/22/10 11:05 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
some more
Re: Engine run-in stands [Re: slowpoke] #621205
02/22/10 11:11 PM
02/22/10 11:11 PM
Wpg, Mb, Canada
six-barrel Offline
six-barrel  Offline
Wpg, Mb, Canada
To add to PC-Chargers comments:
It's an empty tranny case and a junk torque convertor cut in half (then balanced).
Works great had Hemi's, big blocks and small block on it. Nice way to breakin a cam and check for leaks.
Next step is a water brake to apply load to seat rings, etc., etc..
Re: Engine run-in stands [Re: slowpoke] #621206
02/24/10 08:05 AM
02/24/10 08:05 AM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Yeah, we considered using one of the Chevy HHR electric fans but just slapped on that fan instead, with a spare radiator we already had.
The stand was very low cost and effective, we've already had three engines on it and broken in two cams with it. Makes it nice when you have to remove inner springs during a cam break in, much easier than doing it in the car.
We made the stand all bolt together too, which makes it easy to take apart and store in the attic. And its adjustable so we can fit a big block or whatever we want on it.
