v8 a- body conversion #621041
02/22/10 04:56 PM
02/22/10 04:56 PM
wisconsin usa
moretork03 Offline OP
wisconsin usa
looking for a home for my small block.how much work will i be looking at going from a six to a v8 in a 64-sh valiant or a 70-sh duster?
Thanks on advance
Re: v8 a- body conversion [Re: moretork03] #621042
02/22/10 05:08 PM
02/22/10 05:08 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Thanks on advance
buy the mounts 150.00 - 200.00
http://www.engine-swaps.com/
Re: v8 a- body conversion [Re: 340dart4spd ] #621043
02/22/10 05:13 PM
02/22/10 05:13 PM
wisconsin usa
wisconsin usa
no k-member swap?
Re: v8 a- body conversion [Re: moretork03] #621044
02/22/10 05:24 PM
02/22/10 05:24 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
No k-member swap, but then you're looking at a new transmission if you have an auto trans, new radiator (the 18" isn't so good for that and it doesn't have the right outlet/inlet pattern), possibly shorten the driveshaft, all the balancing items for the V8, and all the accessories (the slant alt and PS pump work but you'll need new brackets).
Re: v8 a- body conversion [Re: moretork03] #621045
02/22/10 05:30 PM
02/22/10 05:30 PM
64-66 A, /6 to SB. need set of 64-66 A body 273 V8 mtr mts (not the insulators as they are the same as your/6 ones) or the conversion aftermarket mtr mts which are way more $$$ than the OE ones. ex manifolds from the same above 64-66 273 A body or fenderwall hooker headers or Harolds' spitfires but peruse the feedback over @ www.forabodiesonly.com about them 1st. 340 HP ex manifolds MAY fit if you shorten the coupler to half it's stock length which sounds hokey but actually there is alot depth there and it is saf or I have not done it but a shorter inner shaft from a PS column w the aftermarket extension MAY fit.Then a SB 904 as you know. Find a modern cable from the above 64-66 A body 273 V8 or if you are Ok w drilling 2 holes in the firewall just use a common SB throttle pedal/cable from any 67 up SB A body. Can use either the early cast iron WP or any later alum one depending on which side the lower radiator nipple is located. Almost forgot on 1 of the metal mt mts you need to weld on a triangle piece to match the block mtr mt lugs (& the info is in the archives). In my experience if this is anything more than grannys grocery getter dont use the 273 logs, step up to something less restrictive. PPS bolt on the trans crossmember then trim a scallop in the one side to match the frame cutout on the other side then take it off and box it across for strength, this will let you tuck your dual ex up tight to the floor.
Re: v8 a- body conversion [Re: sharpie] #621046
02/22/10 05:33 PM
02/22/10 05:33 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I'm doing it right now but with a '73 swinger. I think the early cars might have a tighter engine compartment? On my (spool mount) car I got used schumacher conversion mounts and I still have to cut the drivers side 1" lower on the K.
Are you going to do away with the ball and trunion stuff on the driveshaft and just go with a regular 904 trans? Are you going to swap the axle, radiator, brakes, other stuff that won't work good with 2x the power?
Re: v8 a- body conversion [Re: radar] #621047
02/22/10 08:46 PM
02/22/10 08:46 PM
united states
badrap Offline
badrap  Offline
united states
i have a 73 swinger that i am pulling in this weekend to start work on ,its a /6 we are probably putting a 360 in it.
Re: v8 a- body conversion [Re: badrap] #621048
02/22/10 08:53 PM
02/22/10 08:53 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Don't forget the right oil pan...
Re: v8 a- body conversion [Re: 340dart4spd ] #621049
02/22/10 09:07 PM
02/22/10 09:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The 64 will need a V8 centerlink too, the 73 comes with it already. Took me one day, start to finish, to swap out the 225 for a 360 in my 72 Swinger, but I had everything on hand, had to do a K member swap, no conversion mounts back then.
Don't be the exception.
Re: v8 a- body conversion [Re: Supercuda] #621050
02/22/10 09:16 PM
02/22/10 09:16 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Did my first 68 440 big block swap in 88...With no aftermarkert mounts..had to make my own......that was fun fun fun...
