Re: v8 a- body conversion
[Re: moretork03]
#621042
02/22/10 05:08 PM
02/22/10 05:08 PM
340dart4spd
Parts Problem
Parts Problem
looking for a home for my small block.how much work will i be looking at going from a six to a v8 in a 64-sh valiant or a 70-sh duster? Thanks on advance
buy the mounts 150.00 - 200.00
http://www.engine-swaps.com/
[Re: moretork03]
#621045
02/22/10 05:30 PM
02/22/10 05:30 PM
RapidRobert
64-66 A, /6 to SB. need set of 64-66 A body 273 V8 mtr mts (not the insulators as they are the same as your/6 ones) or the conversion aftermarket mtr mts which are way more $$$ than the OE ones. ex manifolds from the same above 64-66 273 A body or ![](/ubbthreads/images/graemlins/tsk.gif) fenderwall hooker headers or Harolds' spitfires but peruse the feedback over @ www.forabodiesonly.com about them 1st. 340 HP ex manifolds MAY fit if you shorten the coupler to half it's stock length which sounds hokey but actually there is alot depth there and it is saf or I have not done it but a shorter inner shaft from a PS column w the aftermarket extension MAY fit.Then a SB 904 as you know. Find a modern cable from the above 64-66 A body 273 V8 or if you are Ok w drilling 2 holes in the firewall just use a common SB throttle pedal/cable from any 67 up SB A body. Can use either the early cast iron WP or any later alum one depending on which side the lower radiator nipple is located. Almost forgot on 1 of the metal mt mts you need to weld on a triangle piece to match the block mtr mt lugs (& the info is in the archives). In my experience if this is anything more than grannys grocery getter dont use the 273 logs, step up to something less restrictive. PPS bolt on the trans crossmember then trim a scallop in the one side to match the frame cutout on the other side then take it off and box it across for strength, this will let you tuck your dual ex up tight to the floor.
[Re: badrap]
#621048
02/22/10 08:53 PM
02/22/10 08:53 PM
340dart4spd
Parts Problem
Parts Problem
i have a 73 swinger that i am pulling in this weekend to start work on ,its a /6 we are probably putting a 360 in it.
Don't forget the right oil pan...
[Re: 340dart4spd ]
#621049
02/22/10 09:07 PM
02/22/10 09:07 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The 64 will need a V8 centerlink too, the 73 comes with it already. Took me one day, start to finish, to swap out the 225 for a 360 in my 72 Swinger, but I had everything on hand, had to do a K member swap, no conversion mounts back then.
[Re: Supercuda]
#621050
02/22/10 09:16 PM
02/22/10 09:16 PM
340dart4spd
Parts Problem
Parts Problem
Did my first 68 440 big block swap in 88...With no aftermarkert mounts..had to make my own......that was fun fun fun...
