Page 6 of 10 1 2 4 5 6 7 8 9 10
Re: accident at Phoenix? [Re: Streetwize] #619897
02/23/10 10:42 AM
02/23/10 10:42 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Well with full respect....being in industrial engineering for 30 years and being flown 1/2 around the world to seek my opinions for FMEA (Failure Modes and Effect analysis) studies I think I have at least a "clue"...any safety system designed by man gets improved upon and upgraded as soon as something that was "NOT supposed to Happen" happens, Darrel Russell is a very good example of something that everyone knew could happen (a tire breaking apart and tail-whipping) but was not addressed until a low probability occurence quite tragicly took his life.
Fatalities happen in racing and in industry, it all comes down to "acceptable risk" and hoping the safety measures enacted are adequate to mitigate that risk.....upgrading those measures are often expensive (except DR's accident seems not so expensive and in a tragic irony now almost seems "common sense"....quite unfortunately from time to time the bar must be raised and there are always those who resist because of the expense of the redesign.
I'm sure may of you may be familiar that in Industry we use many "torque to yield" break -away bolts and nuts that are essentially double nuts where torque is applied to the top nut and it shears off leaving only the properly torqued bottom nut in place. That's only mentioned as an example of how often engineering must take the human error factor out of the equation but even that is only as good as its certification method.
There is no question in my mind that a wheel/wheel securing system could be designed with adequate strength for TF and F/C that would keep the wheel secure to a axle hub....it may not keep the tire on the wheel (another matter fro discussion) but it could certainly keep the wheel on the axle.
I'll bet you Antron's wheel looks just like mine did. The inner wheel stayed bolted to the car and the outer separating. I guess they have to make the wheels heavier?
Re: accident at Phoenix? [Re: Streetwize] #619898
02/23/10 10:53 AM
02/23/10 10:53 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Sadly, this is a factor in a LOT of industry today and yesterday. Look at Ford's decision not to spend $50 per car on a redesign of the Pinto gas tank...the airlines have an expression for this, not trying to be glib, but they call it 'tombstone technology'.....
Re: accident at Phoenix? [Re: Challenger 1] #619899
02/23/10 10:54 AM
02/23/10 10:54 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Yes, unfortunately.
One could easily imagine how the Forces of a Top fuel car experiencing severe tire shake could very likely exceed the calculated strength of the materials used in the wheels...you are going from instantaneous free-wheeling to instantaneous braking forces (as the tire tries to grab traction) occuring how many times per second?
WIZE
In Car:
Re: accident at Phoenix? [Re: torredcuda] #619900
02/23/10 11:55 AM
02/23/10 11:55 AM
Arizona
Jeffaary Offline
Jeffaary  Offline
Arizona
Wheel tethers,fences-Nascar has 3500# cars hit the fence and bounce off.
NASCAR & Indy cars have also had their tires bounce OVER those catch fences and kill spectators. Catch fences are not a 100% solution. Did you see the footage of this crash? The tire was pretty low at first, just barely clearing the chest-high concrete wall. Then it hits something, either the unfortunate lady or the yellow truck, and at that point it starts bouncing sky-high. A wheel/tire that heavy and with that much inertia/momentum/energy is tough to contain. I'd rather focus my efforts on not letting the tire break away in the first place.
Re: accident at Phoenix? [Re: Jeffaary] #619901
02/23/10 12:09 PM
02/23/10 12:09 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I'll get flamed for this. I feel sorry for the family and mean no disrespect to them at all. Death happens, it is a fact of life. It just seems odd to me that some many people die every year from someone who gets drunk and then drives a car only to hit some innocent person and kill that person. No one seems to want to do anything about that. If we spent the time to engineer something to prevent that tragedy, then we would save many more lives than the ones killed in racing accidents!
Re: accident at Phoenix? [Re: torredcuda] #619902
02/23/10 12:58 PM
02/23/10 12:58 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Nascar is just plain lucky IMO. Check out this audience side fence cable restraints at this past Daytona race. The cables are likely to load the latch closer, a big safety mistake in design.
Re: accident at Phoenix? [Re: jcc] #619903
02/23/10 01:04 PM
02/23/10 01:04 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Maybe this pic makes more sense
Re: accident at Phoenix? [Re: Jeffaary] #619904
02/23/10 01:08 PM
02/23/10 01:08 PM
NH
torredcuda Offline
torredcuda  Offline
NH
There are no 100% solutions as yes,accidents will always happen but I think a lot more can be done to improve safety.Look at all Nascar has done in recent years-safer barriers,complete new car,better seats,hans device etc.
Re: accident at Phoenix? [Re: torredcuda] #619905
02/23/10 02:44 PM
02/23/10 02:44 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
As far as the nitro cars go these rockets are breaching sanity and that's their primary draw. You start taming them then their popularity will dwindle. That said, there is no reason why a better/stronger wheel/hub assembly cannot be devised.
Re: accident at Phoenix? [Re: BobR] #619906
02/23/10 02:52 PM
02/23/10 02:52 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
Arent they called "Accidents" for a reason?
Re: accident at Phoenix? [Re: BobR] #619907
02/23/10 04:28 PM
02/23/10 04:28 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Are you kidding? You are assigning definite blame to human error as the cause of this accident without knowing ANY of the details? These are professionals. They have a routine for lug nut tightening and I can assure you that the severe tire shake Antron was driving through had everything to do with the stud failure.
Could have been stud failure, could have been a wheel failure....... also could have been human failure. Bernsteins top fueler was shut off at the line during elims a couple years ago because (quoting then crew chief Lee Beard) "the crew forgot to put oil in it." I'm sure those professionals had a routine for that too.
A spectator fatality is a huge legal deal. A lot of eyes are going to be taking a hard look at the cause. This will go far beyond just NHRA.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: accident at Phoenix? [Re: nhramark] #619908
02/23/10 05:35 PM
02/23/10 05:35 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I don`t mean to sound dumb but whats a wheel tether? I`ve never seen/heard of it.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: accident at Phoenix? [Re: 11secdart] #619909
02/23/10 05:40 PM
02/23/10 05:40 PM
organ
maximum entropy Offline
organ
f1 uses 'em. in the event of wheel/ suspension failure the wheel (usually) stays with the car.
Re: accident at Phoenix? [Re: maximum entropy] #619910
02/23/10 05:59 PM
02/23/10 05:59 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Don't know how that would have made any difference in this situation. The F1 tethers are attached to the suspension assembly and not the wheel.
Re: accident at Phoenix? [Re: BobR] #619911
02/23/10 06:09 PM
02/23/10 06:09 PM
organ
organ
really, i'm amazed this doesn't happen almost every time they rattle the tires. the slomo video is painful to watch, literally shaking the car (and driver) to pieces.
Re: accident at Phoenix? [Re: maximum entropy] #619912
02/23/10 06:12 PM
02/23/10 06:12 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats when you should lift and try it again, which is what he did and what probably caused the problem
Re: accident at Phoenix? [Re: maximum entropy] #619913
02/23/10 06:24 PM
02/23/10 06:24 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I asked this question a couple of years back and got no response, then if "tire shake" is the main culprit, what causes it, what would prevent it, and it is a recent problem ( don't remember it in the 60's??)? Myabe we can't see the forest from the trees.
Re: accident at Phoenix? [Re: nhramark] #619914
02/23/10 06:38 PM
02/23/10 06:38 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Tim Wilkerson's son lost both wheels off his car last summer. Lug nuts were left loose. Brandon Bernstein also lost a wheel a few years ago and went over the wall. It can happen.
Re: accident at Phoenix? [Re: jcc] #619915
02/23/10 06:42 PM
02/23/10 06:42 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
The wheels, studs, and axles are all SFI approved and engineered for the load applied.
I believe it is quite likely that the nuts were over/under torqued on the wheel that failed.
Don't worry, though, NHRA has a complete investigation underway and will reveal the results soon...just like they did after Wilkerson lost BOTH wheels last year, and Russell was killed after blowing a tire!!!
Re: accident at Phoenix? [Re: jcc] #619916
02/23/10 07:35 PM
02/23/10 07:35 PM
Cincinnati, Ohio
Cincinnati, Ohio
Tire shake...one of the hardest things to tune around with a car with big power. There's many different reasons it happens, but it's always from the car not getting up on the tire at the right time.
