The attached pic is supposed to be of a 69 and older a833 tail shaft.
1st, is this a 69 or older tail shaft? I think it is, but want to be sure.
2nd, there's a bolt and orange bracket located near the three shifter mounting holes. Is this a factory bracket, or has it been added? I've looked at a few other pix of these shafts and I'm not seeing a provision for this bracket.
I'm needing to swap out the shaft on my 4spd because it's a 71 up B/E with the tranny mounting pad in the wrong spot to use for my 65 coronet. So I'm looking for a 69 and older tail shaft to swap out.
Just want to be sure I'm getting the correct part.
