Help me id this tail shaft & as it been modified? #619408
02/21/10 12:49 AM
02/21/10 12:49 AM
Sooner state
Slim Smitty Offline OP
Sooner state
The attached pic is supposed to be of a 69 and older a833 tail shaft.
1st, is this a 69 or older tail shaft? I think it is, but want to be sure.
2nd, there's a bolt and orange bracket located near the three shifter mounting holes. Is this a factory bracket, or has it been added? I've looked at a few other pix of these shafts and I'm not seeing a provision for this bracket.
I'm needing to swap out the shaft on my 4spd because it's a 71 up B/E with the tranny mounting pad in the wrong spot to use for my 65 coronet. So I'm looking for a 69 and older tail shaft to swap out.
Just want to be sure I'm getting the correct part.
- - - - - - - 65 Coronet
Re: Help me id this tail shaft & as it been modified? [Re: Slim Smitty] #619409
02/21/10 12:53 AM
02/21/10 12:53 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
The orange bracket would be to retain the speedometer adaptor...
Re: Help me id this tail shaft & as it been modified? [Re: OzHemi] #619410
02/21/10 01:25 AM
02/21/10 01:25 AM
Sooner state
Sooner state
Okay, I found some better reference pix and the bracket mount is correct.
Re: Help me id this tail shaft & as it been modified? [Re: Slim Smitty] #619411
02/21/10 09:45 AM
02/21/10 09:45 AM
scratchnfotraction Offline
yes its the speedo plug clamp...looks to have a plug in the hole to delete it
is it a core plug or part of the casting not drill out?
