Holley 3310 Tricks?
#618728
02/20/10 12:44 PM
02/20/10 12:44 PM
Posts: 910 Southern Oregon
toyotajeep
Southern Oregon
I am finishing off my low-buck 440 Dart. I am running a mild 440 with some gears and other stuff. Most of its use will be daily driving with 3-4 times a year to the track. I should note that I live at 4500 ft and the tracks are around 1000 ft elevation.
I have a 3310-2 Holley. It is bone stock and not modified at all.
It needs a rebuild. I am looking at an AED brand for the kit. I will likely do some jetting and tuning. I am not the kind of guy who wants to rebuild the thing everynight, but I would like it to perform well.
What are your thoughts on adjustable secondary kits, jetting the secondary side? What about the fuel lines? They run from $18.00 to over $100. I will be in and out of the primary jetting some I am sure.....
What are your ideas on the best bang for the buck? I don't want a $350 used 750.....but I don't want to give up a .5 second at the track either.
Thanks people.
ROB
1989 Dodge Cummins & 1989 Dodge W-250
Re: Holley 3310 Tricks?
[Re: toyotajeep]
#618729
02/20/10 12:52 PM
02/20/10 12:52 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
I hate holleys but one thing I learned, since you have to tune them all the time you should get a flexible fuel line, it makes it easier to remove one bowl or the other even if the solid line is prettier.
[Re: HotRodDave]
#618730
02/20/10 01:51 PM
02/20/10 01:51 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I would buy a rebuild kit and depending on your cam start with a 6.5 or 5.5 power valve. Maybe start with 68 front jets and just leave the rear alone.
Start there and I'll bet you never have to change anything or a size or two jets max. set fairly right they go years without any more adjustments
[Re: HotRodDave]
#618732
02/20/10 03:22 PM
02/20/10 03:22 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
I hate holleys but one thing I learned, since you have to tune them all the time...
Not true.
[Re: Junky]
#618733
02/20/10 03:40 PM
02/20/10 03:40 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Not true.
I agree that it is not true. Once they're set up, they stay set up. I don't understand where the unreliabilty URBAN LEGEND comes from...
[Re: hemicar1971]
#618735
02/20/10 04:21 PM
02/20/10 04:21 PM
HotRodDave
Kalispell Mt.
The ledgend is rooted in truth and experiance, they need jet changes from altitude changes and temp changes and sometimes they want changes for no good reason. Idle screws seem to need tinkered with every so often to keep them idleing there best. I have fooled with carbs all my life and none of them seem to be as finiky about minor changes than holleys.
Part of some peoples frusteration comes from blown power valves from backfires witch somereason holleys like to backfire more than any other carb when you are trying to tune them. Power valve check valves have definately been a big help in that department.
[Re: HotRodDave]
#618736
02/20/10 04:47 PM
02/20/10 04:47 PM
Junky
Wherever I am.
And what carb doesn't get affected by altitude and heat changes? And for no good reason? For example...
[Re: Commando1]
#618738
02/20/10 05:11 PM
02/20/10 05:11 PM
dulcich
Not true.
That urban legend really is based on fact, and now I'm going to explain where most of it comes from. Back in the day the gaskets were junk, if you let the carb sit the cork would shrink like crazy and dry out, carb wouldn't run right, fuel leaks all over. This was especially true with the common rebuild kits. Happened all the time. New good gaskets from Holley, like the no-stick blue ones last virtually forever and give almost no problems. -dulcich
[Re: dulcich]
#618739
02/20/10 08:07 PM
02/20/10 08:07 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
""I hate holleys but one thing I learned, since you have to tune them all the time... ""
The tech from Quick Fuel told me that the more accurate the metering systems are on a carb, the more they are affected by temperature changes. I remember a stock 318 that I had and I never touched that two barrel in 5 years of driving it, Winter thru Summer. The last couple of carbs (QF, & Speed Demon)that I have had did need the metering screws tweeked when the temps changed 15-20 degrees. I don't mind since the car is my weekend toy.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Commando1]
#618741
02/21/10 11:08 AM
02/21/10 11:08 AM
toyotajeep
Southern Oregon
OK. I am going to break out my Holley book this week. A good kit, maybe buy the bling adjustable secondary spring kit through AED.
It sounds like the fuel line issue along with secondary jetting options are the big choices at the moment.
I could do the idea of the black rubber hose connecting the two ends, and then slip the solid line in once things get figured out.
Another thing, I think they use a different line depending on if I change over to jettable secondaries. Better get that figured out in my planning before I buy a $80 line kit.
ROB
[Re: Magnum]
#618744
02/21/10 12:19 PM
02/21/10 12:19 PM
HotRodDave
Kalispell Mt.
If you buy a line and cut it and install the rubber hose you can later install the secondary block and just slide the hose out farther and still use the same line.
[Re: toyotajeep]
#618745
02/21/10 01:11 PM
02/21/10 01:11 PM
Posts: 2,005 s. e. pa.
calrobb2000
s. e. pa.
hi what intake , gears , headers , timing curve ? they all have to work together !
[Re: calrobb2000]
#618746
02/21/10 01:26 PM
02/21/10 01:26 PM
toyotajeep
Southern Oregon
Holley Street Dominator
Stock ignition-I think some of my issues are there. It is going to get fixed first.
home ported 452 castings
223-230 Hughes cam
4.10's
It is a budget racer that I can drive to work as well. Low compression 76 440.
ROB
