72 Charger Fenders
#61681
05/22/08 04:07 PM
05/22/08 04:07 PM
Posts: 270 Pa
Rallyehunter
Pa
Hello, can someone please tell me what the difference is between 71-72 fenders and 73-74 fenders? Now I know the side marker light is different on the 71 and 72 fenders, but how about the 73-74 fenders compared to the 72s. I was told the bodyline is different, the wheel opening is bigger and the front edge is drilled for chrome on the 73-74 fenders. Can anyone clear this up for me? please Thanks Bob P.S. Does anybody have a good passenger side fender for sale that’s reasonable?
Re: 72 Charger Fenders
[Re: Rallyehunter]
#61683
05/22/08 04:56 PM
05/22/08 04:56 PM
I have often wondered. The 71-72 WOM's are different from the 73-74 so there may be a difference right there. I actually have a 72 sitting here with no fenders on it, and a 74 fender sitting on it's deck, so I will go look and maybe mock it up in an hour or so. There are 71 fenders right there too to compare the lip, although I am unsure if I have 72 ones at all.
[Re: Rallyehunter]
#61685
05/22/08 07:29 PM
05/22/08 07:29 PM
Posts: 12,521 Western Colorado High Desert
moparmarks
Thanks Bob
You pretty much have it. 3/4" difference in the body line. 73/4 wheel opening is larger.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: Rallyehunter]
#61688
05/23/08 05:10 PM
05/23/08 05:10 PM
Posts: 6,109 Valencia, España
NachoRT74
Valencia, España
you can mount a 72/71 on to a 73/74 and backwards without problem... body lines will match PERFECTLY... diff are:
-ONE bolt on inner fender -higher cut on 73/74 opening wheel well -front splash shield ( the one what bolts with valence ) needing to get the matching splash shield with fender. The area on 73/74 where this shield attachs is larger and "folded, covering lot more than earliers. -Of cours the sidemarker, but that is just on 71
[Re: NachoRT74]
#61689
05/24/08 11:29 PM
05/24/08 11:29 PM
moparmarks
Sorry my bad. You are correct. I was thing of where the body line meets between the door and the quarter there is 1.75" difference.
