late model manual trans to LA engine
#613396
02/14/10 04:42 PM
02/14/10 04:42 PM
Posts: 118 Portland,Or
chargersNW
Portland,Or
I am looking for a post or some information on installing a late model 5sp manual behind and early LA series 360 including good donor cars for such parts, etc.
Re: late model manual trans to LA engine
[Re: chargersNW]
#613397
02/15/10 05:48 PM
02/15/10 05:48 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
The only late model 5 speed manual that will bolt to a small block is a NV3500.
It's a 5 speed from Dakotas and Rams.
1st gear is too low for a car. It's 4.0:1. Ratios are too wide for racing and it's big x huge and will not fit into a car without extreme modifications.
[Re: ahy]
#613400
02/16/10 09:24 AM
02/16/10 09:24 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
3.9 dakotas ip to 96ish used an Aisin AX15. if you get the bellhousing from one, you can bolt on an aisin R154 (toyota supra tranny). getting it to fit in the tranny tunnel is another issue.
if it's a light car with a mild 318, you can adapt a T-5 fairly easily.
[Re: volaredon]
#613402
02/16/10 12:55 PM
02/16/10 12:55 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Don't forget the New Process A535 from the early Dakotas. They pop up on ebay frequently for $600 rebuilt.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: QuickDodge]
#613404
02/16/10 02:52 PM
02/16/10 02:52 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The T5 is a garbage transmission. It'll hold up OK for granny use on an itty bitty V8.
[Re: feets]
#613405
02/16/10 03:55 PM
02/16/10 03:55 PM
Fury Fan
Indiana
T5 isn't bulletproof but it isn't garbage, either. Lots of 86-93 Mustang guys pounded on them back in the day - and still do. Like most things, there are some versions that are stronger and there are a few weakness that can be upgraded without breaking the bank. All depends on what your goals are... Here's an adapter bell from SB to Ford transmissions: http://www.safepay.net/cgi-bin/shop/cart...moderndrivelineHere's a thread that's worth reading: https://board.moparts.org/ubbthreads/show...part=1&vc=1
Parts I seek:
Send a PM.
[Re: volaredon]
#613408
02/17/10 09:04 AM
02/17/10 09:04 AM
Fury Fan
Indiana
Volaredon's right, there are some on clearance almost 1/2 price from QT. The link I posted is a little cheaper otherwise though. Either way, as with most things, once you find a mfg part# it's best to shop around.
Parts I seek:
Send a PM.
