Re: Which 426/472/528 Hemi crate motor worth buying
[Re: rodthedeerguy]
#612411
02/13/10 02:37 PM
02/13/10 02:37 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
He assembles them for MP.Whats that tell you.He has been doing Hemis for years.Rocky
Chrysler Firepower
[Re: therocks]
#612412
02/13/10 09:36 PM
02/13/10 09:36 PM
Posts: 13 Jacksboro, TX
rodthedeerguy
Jacksboro, TX
I am going to contact his company Monday and see if he has a cam or intake or any suggestions about sorting out my problem. Thx for your input.
Update: Spoke to Ray Barton yerterday. Says early MP crate motors are of poor parts and assembly quality. Says he saw at cumins with his own eyes heads pulled right out of the box installed on the shortblock with metal shavings in the ports and on the heads among other alarming procedures. Says he has inspected and fixed many MP crates and has seen a myriad of problems. I do not believe he was exaggerating. I believe his reputaion and business practices are more important than misleading me. Would anyone disagree about Ray? Can he be trusted, completely? He sure was helpful. He is a fan of the 528 over 472's and 426's.
[Re: bobbyb]
#612418
02/19/10 04:04 PM
02/19/10 04:04 PM
therocks
Niles , Ohio
bobby with the early crates it was a crap shoot.Some were great others total junk that took a lot to get right.You must have got one of the good ones.Rocky
Chrysler Firepower
[Re: rodthedeerguy]
#612419
02/20/10 06:12 PM
02/20/10 06:12 PM
Posts: 878 hudson valley n.y.
GEORGE68HEMIRR
super street
super street
hudson valley n.y.
ray barton is no good ....do yourself a favor and call tim bannings.....you can trust him and he stands behind his work...http://forhemisonly.com/
[Re: GEORGE68HEMIRR]
#612420
02/20/10 07:37 PM
02/20/10 07:37 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
I have a Barton 528 hemi. Ray showed me around the shop including a bunch of blocks he was REJECTING. He showed me the problems with them. They check every one well for core shift and other problems. Barton is an excellent Hemi builder. Tim Banning also has an excellent reputation and all things being equal it'd be a tossup.
#612422
02/21/10 10:19 AM
02/21/10 10:19 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I vote Tim Banning. He could probably build you more engine for the same money.
[Re: desomod]
#612424
03/02/11 09:04 PM
03/02/11 09:04 PM
Posts: 1,379 Houston,Tx.
Lee446
Houston,Tx.
Current RB/MP 528 crates are rated at 610 hp. In a article I read, Barton says they are all dynoing at 640+. Some of the crates used Comp cams and some used Engle K-8's. The Engle, if I recall correctly from a conversation with them was around 244@50, .559 lift on 108. I believe I had read the comps were a bit smaller. I have no idea who Barton is using. My experience and that of many others here, is that the quality of build from Cummins is junk. My 528 was not honed with torque plates, and was a bit oversized(bore) to boot. Valve guides were so loose, 3 ex valves were bent right off the bat. Rod bearings were chamfered by Fred Flintstone with a stone axe. No windage tray installed, sloppy timing set, adnauseum. With Stanton and Barton as builders, I would have confidence in them, but I would buy a custom engine from them for probably the same money, that would be tailored to your specs, other than a "Crate" build.
