Indy Heads and What Headers??? #612298
02/13/10 10:53 AM
02/13/10 10:53 AM
pro99 Offline OP
pro99  Offline OP
I know this has been asked but please don't shoot me for asking again. Does anyone know where the best place is or the cheapest place to buy the Indy 440-1K Max Wedge Aluminum Kit? Does anyone know of a good used kit or just heads for sale?
Also is this the best bang for the buck or is there another set of heads out that can perform or out perform them for the money?
I have a 68 Dart with a 500ci with 11.5 to 1 with cast heads and looking to upgrade to better flow and maybe raise the comp to 12 to 12.5 to 1. I also have fenderwell headers but want to change them out do to they are rusted up and look like junk. What would be the best set of headers to run TTI or another set of fenderwell headers and what would be the best fenderwell headers to run?
1968 Dart Drag Car (I just bought it)
Re: Indy Heads and What Headers??? [Re: pro99] #612299
02/13/10 03:22 PM
02/13/10 03:22 PM
pro99 Offline OP
pro99  Offline OP
Anybody got any info at all
Re: Indy Heads and What Headers??? [Re: pro99] #612300
02/13/10 05:16 PM
02/13/10 05:16 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
You might be looking for something that'll give you a little more power, but have you thought about the Indy EZs? They're made for A-bodies and I believe that you can use regular headers (no raised exhaust ports). I have a set of the SRs and (just like the 440-1 heads, you have to use the TTI headers ($700) or go custom.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Indy Heads and What Headers??? [Re: 1968RR] #612301
02/13/10 05:19 PM
02/13/10 05:19 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think its the "SR"s that are made for a-bodies. The EZ's have stock exhaust port locations.
Re: Indy Heads and What Headers??? [Re: Stanton] #612302
02/13/10 06:06 PM
02/13/10 06:06 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
You may want to check into Indy EZ-1 heads, that way you can just buy a new set of fenderwell headers. You may be able find a nice used set of heads.
Re: Indy Heads and What Headers??? [Re: Darryls-Demon] #612303
02/14/10 12:04 PM
02/14/10 12:04 PM
pro99 Offline OP
pro99  Offline OP
Will the Indy 440-1 heads work in the Dart with the TTI headers with out any cutting or mods? I wanted to replace the inner fender-wells with new replacements from A.M.D to make it look better in the engine compartment anyways. The owner before me cut the fender with a cutting torch and hacked them up bad I think the biggest thing I want to do is build this to be a 10. to 10.2 car on motor alone with no problem. It runs 10.70 now but thinking the cast heads are just killing it right now??? I just want to spend the money one time and be done Will the SRs heads flow good enough to get me to a 10. or better with no problems also on the right motor? If I don't have to spend a lot of money 3900.00 and have to get the 440-1 heads to do what I want then I can go with the SR's heads???
Re: Indy Heads and What Headers??? [Re: pro99] #612304
02/14/10 09:11 PM
02/14/10 09:11 PM
pro99 Offline OP
pro99  Offline OP
Re: Indy Heads and What Headers??? [Re: pro99] #612305
02/14/10 09:20 PM
02/14/10 09:20 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Go here www.Compu-flow.com Nick will set you up with everything you need
Gus
64 Plymouth Savoy
Dana 60
Re: Indy Heads and What Headers??? [Re: Stanton] #612306
02/16/10 02:16 AM
02/16/10 02:16 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
No, the EZs are made for easier header fitment, (A bodies), hence the stock exhaust port height.
SRs have a raised exhaust port.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Indy Heads and What Headers??? [Re: Von] #612307
02/16/10 05:00 PM
02/16/10 05:00 PM
pro99 Offline OP
pro99  Offline OP
But does anyone know if I use the 440-1 heads will the TTI headers fit with out cutting anything or mods to the car?
Re: Indy Heads and What Headers??? [Re: pro99] #612308
02/16/10 05:32 PM
02/16/10 05:32 PM
AndyF Online content
AndyF  Online Content
You don't need 440-1 heads to run low 10s in an A body car. Some CNC ported Edelbrock RPM heads should do the trick just fine. Call around there in MI and get some local help. Muscle Motors, Best Machine, Mancini Racing, Modern Cylinder, etc can all get you the parts you need.
Ported RPM heads, a big flat tappet and a decent carb and intake pkg will put an A body car into the 9's with a 500 inch motor.
