750 or 800cfm ? #611711
02/12/10 07:18 PM
02/12/10 07:18 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Wich one to use with a 408 stroker ?
To me the 750 Eddy souds fine, some say a 800 cfm is a must.....
Any comments ?
Dan
Re: 750 or 800cfm ? [Re: Wedgeman] #611712
02/12/10 07:44 PM
02/12/10 07:44 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
the 750 eddy has alot of complaints. I have an 800 Thunder series AVS. very sweet carb. easy to tweak and tune. Only trouble i've had is it comes off fast idle to soon. Gonna play with it this weekend.
Re: 750 or 800cfm ? [Re: Wedgeman] #611713
02/12/10 08:49 PM
02/12/10 08:49 PM
Az
Crizila Offline
Crizila  Offline
Az
If you got some good breathing heads on it ( 270 or better cfm on the intake side ), the 750 might be a little small. I'd go with an 800 or 850.
Fastest 300
Re: 750 or 800cfm ? [Re: Wedgeman] #611714
02/12/10 09:29 PM
02/12/10 09:29 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Do you have to have an Eddy carb? if o the 800...I'd go for a 750DP
Coming soon!!!!
Re: 750 or 800cfm ? [Re: Mr.Yuck] #611715
02/12/10 09:34 PM
02/12/10 09:34 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
HOLLEYS GIVE ME PIMPLES...
Re: 750 or 800cfm ? [Re: Wedgeman] #611716
02/12/10 09:37 PM
02/12/10 09:37 PM
Dougsmopars Offline
Dougsmopars  Offline
Holley's give me migrains
Re: 750 or 800cfm ? [Re: Wedgeman] #611717
02/12/10 09:42 PM
02/12/10 09:42 PM
either CFM would work for you. If you get a good deal on either size of any model of any brand I wouldn't hesitate. As said alot of complaints on the 750 eddy.
Re: 750 or 800cfm ? [Re: Dougsmopars] #611718
02/12/10 09:43 PM
02/12/10 09:43 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Any other diseases from Holleys ? loll
Re: 750 or 800cfm ? [Re: Wedgeman] #611719
02/12/10 09:46 PM
02/12/10 09:46 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I know someone who has an old 750 carter afb on a 408 and it runs nice. I have ridden around in it and it doesn't cough, hesitate, or do anything irritating. It also runs hard enough to pop the glovebox door open and curl the floormats backwards when you stand on it.
I think either would work, but if your engine is fairly built then the bigger 800 version is the way to go.
Re: 750 or 800cfm ? [Re: Neil] #611720
02/12/10 11:44 PM
02/12/10 11:44 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would go with an 800. A 750 eddy would not be at the top of my list.
Re: 750 or 800cfm ? [Re: DaytonaTurbo] #611721
02/12/10 11:47 PM
02/12/10 11:47 PM
Dougsmopars Offline
Dougsmopars  Offline
What is the CFM of the stock carter that came on 440 B Bodies, GTX, R/T Charger????????
Re: 750 or 800cfm ? [Re: Wedgeman] #611722
02/12/10 11:52 PM
02/12/10 11:52 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
800 CFM
The 750 still leaves a bit of vacuum at wide open throttle as compared to the 800. Your stroker will appreciate the bigger carb at wide open throttle, provided that your heads flow 250 cfm or better.
Re: 750 or 800cfm ? [Re: Dougsmopars] #611723
02/12/10 11:54 PM
02/12/10 11:54 PM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
Run quickly away from Eddys...if you are serious about getting the best performance get a Holley.
Re: 750 or 800cfm ? [Re: dwbiggs] #611724
02/13/10 12:01 AM
02/13/10 12:01 AM
Dougsmopars Offline
Dougsmopars  Offline
There are guys here who swear by holley, by Damon, by Barry Grant , by Eddy, by Carter and they all say to get the best performence use there brand. They all run good when properly tuned. We can have the same agument about tires, gas, oil the color of the sky. Either CFM will work well if tuned correctly. Buy what ever brand your more familiar with to make tuning it easier for you.
Re: 750 or 800cfm ? [Re: Dougsmopars] #611725
02/13/10 12:10 AM
02/13/10 12:10 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I myself like Holley DP's as I have very good results with them and I find them easy to tune. I have a 750 DP on my sons 400 Dart. He has tried an 800 and 850 and went no faster so he ended up going back to the 750 which has run 11.40's in his mild 400 Dart. If you like the Eddy carbs I would agree the 800 Thunder series seem to be better from what I hear. Both the Holley and Eddy carbs can work good as it just boils down to which you care for and have good results with. Ron
Re: 750 or 800cfm ? [Re: Wedgeman] #611726
02/13/10 10:53 AM
02/13/10 10:53 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
too bad I punted the Carter Comp series 625 on my mild 340 swinger for a 750DP and went from 14.teens to 13.80. A holley is a much better carb and for what you have I think you'd be much hapier w/ a holley. Any car is going to need tuning. Holley have much more to play with so I guess that's why some people don't like them.
Coming soon!!!!
Re: 750 or 800cfm ? [Re: Dougsmopars] #611727
02/13/10 10:55 AM
02/13/10 10:55 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
What year? 4 speed or auto? some 440 B's had 3 holleys
What came on the car was not always the best performing carb for the application, only what was cheap at the time.
Re: 750 or 800cfm ? [Re: Wedgeman] #611728
02/13/10 11:12 AM
02/13/10 11:12 AM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
If you want power go with Holley, If you want drive it all the time streetability, go with an Edelbrock.
I have the Eddy 750 and it's a dog
The 800 Eddy did run good on my buddies 408 small block but it seemed small..then he tunnel rammed it. It runs like a bat outta he// now
Re: 750 or 800cfm ? [Re: Dougsmopars] #611729
02/13/10 12:41 PM
02/13/10 12:41 PM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
I'm running an 800 AVS on my 408 it runs great...
Re: 750 or 800cfm ? [Re: Mopar73340] #611730
02/13/10 12:59 PM
02/13/10 12:59 PM
Stow,Ohio
RBSat66 Offline
RBSat66  Offline
Stow,Ohio
Just a thought, but which carb is taller and will it have room under your hood. I have a holley DP on my 66 and I seem to remember I couldn't fit the Eddy on my intake because it was to close to the hood with the air cleaner on.
