Gas guage reading full all the time? #610362
02/11/10 07:59 AM
02/11/10 07:59 AM
P.E.I. eastern Canada
N
newportrider Offline OP
N
I have a 68 Polara I am working on. The gas guage is reading full. Where do I look for the problem? It ran out of gas in the garage last nite so I know the gauge is lying to me!!LOL
Re: Gas guage reading full all the time? [Re: newportrider] #610363
02/11/10 08:42 AM
02/11/10 08:42 AM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Unplug the sender and see if it goes down . Sounds like its grounded somewhere .
Re: Gas guage reading full all the time? [Re: FY1TA] #610364
02/11/10 11:02 AM
02/11/10 11:02 AM
Unplug the sender and see if it goes down.
yes w key "on", unplug it at the tank & if it goes back to E either the sending unit inside the tank is shorted to ground or the wire from the female connector forward to the dash is grounded somewhere along that line under the carpet.
Re: Gas guage reading full all the time? [Re: RapidRobert] #610365
02/11/10 02:27 PM
02/11/10 02:27 PM
N
N
Thanks guys.
Re: Gas guage reading full all the time? [Re: newportrider] #610366
02/11/10 02:53 PM
02/11/10 02:53 PM
New York City
groundpoint6 Offline
New York City
Does the temp gauge work
Re: Gas guage reading full all the time? [Re: RapidRobert] #610367
02/11/10 03:00 PM
02/11/10 03:00 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
After I changed from a 3/8" to a 1/2" fuel pickup, my gas gauge always reads Full, too. Does that sound like the sending unit is shorted as mentioned above, or could it be the float arm adjustment being different between the two pickup assemblies?
Re: Gas guage reading full all the time? [Re: BradH] #610368
02/11/10 03:06 PM
02/11/10 03:06 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
Because this only happened after you changed sending units I would think it had something to do with the float arm
Re: Gas guage reading full all the time? [Re: BradH] #610369
02/11/10 03:08 PM
02/11/10 03:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Unless the arm on the replacemnet unit is a lot higher then the original,which it shouldn't be if you bought the correct sending unit, you have a shorted wire also.
Re: Gas guage reading full all the time? [Re: stumpy] #610370
02/11/10 04:57 PM
02/11/10 04:57 PM
What they said, key on, pull female connector off & if it goes back to E then plug it back in & if it goes back to/stays at F then run it out of gas as close as you dare and pull the sender & check it's ohms w the float "up" and "down". iirc the specs are 73? & 10 ohms but with it reading full constantly then it'll be apparent where it's grounded. W the sending unit electrical located halfway up on the side of the tank the whole thing gets submerged when the tank if filled and it's in effect a dead short to ground just like when you ground the female connector and that's why the gauge stays on F for along time when you first fill the tank until the level goes down far enough so it's actually below the windings then the gauge starts to show the correct reading.
Re: Gas guage reading full all the time? [Re: groundpoint6] #610371
02/12/10 07:27 AM
02/12/10 07:27 AM
N
N
No it doesn't at present, but the wiring is messed up by the alternator. I haven't got to that area yet.
Re: Gas guage reading full all the time? [Re: newportrider] #610372
02/12/10 03:57 PM
02/12/10 03:57 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
Check for 5 volts at the strip leading to the fuel gauge, It is possible that your voltage limiter is not working.
