Re: Bled brakes today - still outta whack?
[Re: sharpie]
#608609
02/10/10 05:28 PM
02/10/10 05:28 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
So what's the consensus on pumping multiple times in between cracking the bleeder? Is it more, less, or no more effective than just pumping it once and holding to the floor?
FWIW...I've always pumped it a few times when doing it that way...
(or pressure bleed it, I made up a plate ages ago to fit the Aussie PBR master cylinders, worked great)
[Re: sharpie]
#608611
02/10/10 05:44 PM
02/10/10 05:44 PM
OzHemi
Garden Grove, CA
I was heading out to the garage soon to work on the car and could snap a pic with my phone, but basically I just took a piece of steel plate, drilled a hole in it, and welded in a quick connect fitting for my compressor air line, then just glued a piece of rubber onto the bottom of the plate. Then just put the plate over top of the master cylinder and clamp it down (just used a big clamp over the top of it and under the master cylinder) I also use a air regulator before the plate, since you don't want full pressure for it... Then just hook it all up, hook the air up too it, make sure the master cylinder is full, and start cracking bleed screws.
[Re: OzHemi]
#608613
02/10/10 05:51 PM
02/10/10 05:51 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Sounds like a great idea, but without a really efficient drier, couldn't this potentially introduce moisture into the system?
[Re: sharpie]
#608614
02/10/10 05:52 PM
02/10/10 05:52 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
I can think of a way I can do this. The problem for me is the welding part. But if I just tapped the plate it might work....
Either tap the plate or drill the hole large enough to use a couple rubber/plastic washers and a nut on the backside.
[Re: sharpie]
#608615
02/10/10 05:57 PM
02/10/10 05:57 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
You only need 10-15 psi If it will be used only once in a while you can use a small garden sprayer to make one. The plate for the master is easy to make too. Just get yourself a piece of metal just larger than the top of the master, tap the top for air fitting, get a piece of rubber from the hardware store and cut to be used as a gasket. If you have an extra master cylinder cap you can modify that to be used. Put a quick disconnect on your pressure bleeder and fill. As for attaching the plate to the top of the master there are several ways to do that too. http://www.bmw-m.net/TechProc/bleeder.htmI have several of these lying around from when I used to work at a dealer.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#608616
02/10/10 05:58 PM
02/10/10 05:58 PM
Posts: 7,759 So Cal
HealthServices
So Cal
the back side.
Remember you do not need a lot of pressure! Last thing you want is brake fluid sprayed all over you newly painted engine compartment.
Allen
[Re: GTXKen]
#608622
02/10/10 06:38 PM
02/10/10 06:38 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Even at the dealer I am used to working alone. So I have a lot of this stuff at my disposal. Having it at home now, just makes things easier.
Allen
[Re: sharpie]
#608626
02/10/10 06:52 PM
02/10/10 06:52 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I think it is a standard mopar cap. If you cannot find one there go by a junkyard and get one off a junk 70-80s mopar
Allen
