A-12 hi-po exhaust manifolds for 3/29 dated car
#607205
02/07/10 04:01 PM
02/07/10 04:01 PM
Posts: 126 Indiana
F6F6Dodge
Indiana
I am looking for a set of these for a m-code car built on 3/29....does anyone know what numbers or date codes should be on the correct set of manifolds to match a 3/29 car??? Thanks for any and all help!!!!RH SIDE # 2806900 THE LEFT SIDE #2843992 what do these numbers mean???
Re: A-12 hi-po exhaust manifolds for 3/29 dated car
[Re: F6F6Dodge]
#607210
02/07/10 11:23 PM
02/07/10 11:23 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
The part numbers you listed are correct. The casting date codes normally appear on the manifold as well. Generally near the part number.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#607211
02/07/10 11:36 PM
02/07/10 11:36 PM
Posts: 3,378 KY USA
mopargem
KY USA
see the date casting on the left *2 19 69* these would probably fall right in line for your car, maybe to early but I need them for my 4/26 A12
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: F6F6Dodge]
#607214
02/08/10 03:17 PM
02/08/10 03:17 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
thanks for all your help...basically look for the casting numbers with a date stamp a month or so ahead of the 3/29..correct??
Not for an A12! You need to use the engine assembly date stamped on the top pad to the right side of the distributor looking from the front. It's next to the front of the driver's side cylinder head. It is a 2 or 3 digit number such as indicating the month and day the engine was assembled. For example, mine is a 426 SPD on the fender tag but the engine is 6 3. All my original date coded parts preceed 6/3/69 but are mostly dated after 4/26/69. It will be the same on your car. If you do not have the original block, look for the date code in the front of and in the middle of your k frame. That is a close date to when your real production date was. Your date codes should be before that date by 1-4 weeks or sometimes even earlier.
