Had it with the reproduction six-pack idle solenoids #606288
02/06/10 06:11 PM
02/06/10 06:11 PM
Shoreline, Washington
72roadrunnergtx Offline OP
Besides the overall poor quality manufacturing it takes 15-20 seconds to fully energize when warm. When it does it's so weak the slightest downward pressure causes it to collapse. After 3k miles, plunger shaft boot already has holes wearing through. Just no longer care if it doesn't look original, need it to work and not willing to pay $400-500 for NOS. Pretty sure I saw another post here awhile back about using the Holley generic solenoid and fabricating a bracket for it but couldn't locate it just now. Wanted to give credit where it was due. Here's my version of the Holley solenoid change over.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Had it with the reproduction six-pack idle solenoids [Re: 72roadrunnergtx] #606289
02/06/10 06:19 PM
02/06/10 06:19 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yea, I hear it allot, pretty sad state of affairs, the reproductions look great on the outside but the manufacturer went cheap on the internal wire and made them weak. Door is wide open for someone to use what's currently available and come up with better internals.
Re: Had it with the reproduction six-pack idle solenoids [Re: 72roadrunnergtx] #606290
02/06/10 06:19 PM
02/06/10 06:19 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The holley solenoid looks to me like it'd bolt in place of where your old one was. Looks basically like the stock one to me, with the wire in a different spot. Solenoid "only" costs 75 bucks.
Re: Had it with the reproduction six-pack idle solenoids [Re: DaytonaTurbo] #606291
02/06/10 06:24 PM
02/06/10 06:24 PM
Pictures are of the replacement modified Holley #46-74 solenoid. Should have mentioned I altered the spade connection to exit out the side rather than straight down and used the repo lower boot.
Re: Had it with the reproduction six-pack idle solenoids [Re: 72roadrunnergtx] #606292
02/06/10 06:37 PM
02/06/10 06:37 PM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
Just curious about the micro-switch on your throttle, is it for the solenoid?
Re: Had it with the reproduction six-pack idle solenoids [Re: charger440sixpak] #606293
02/06/10 08:48 PM
02/06/10 08:48 PM
The micro switch is set up to be part of my A/C compressor auto cut-out circuit. Acts as a simple throttle position switch, closed through 15-20 degrees off idle. Combined with a basic RPM activated switch control, set to about 3k rpms, and a relay the compressor never sees high revs and is automatically shut off when I open up the center carb and forget about having the A/C on.
Better angle
Re: Had it with the reproduction six-pack idle solenoids [Re: 72roadrunnergtx] #606294
02/06/10 08:58 PM
02/06/10 08:58 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've done basically the same thing with my 6 pak cars, retrofited with the currently avaliable line of Holley solenoids, that range anywhere from $40-$80,....the "repro" or "reconditioned" factory solenoids offered by various individuals are just plain junk
Mike
Re: Had it with the reproduction six-pack idle solenoids [Re: DAYCLONA] #606295
02/06/10 09:34 PM
02/06/10 09:34 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Mike
Please elaborate
Re: Had it with the reproduction six-pack idle solenoids [Re: 72roadrunnergtx] #606296
02/06/10 11:10 PM
02/06/10 11:10 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
does it actually raise up and stay?what is approx distance it will raise?1/4 inch?thanks rick
Re: Had it with the reproduction six-pack idle solenoids [Re: rbkt65] #606297
02/06/10 11:43 PM
02/06/10 11:43 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Thank you for the info. That is a pretty trick setup with the A/C cut out switch also. You might want to add a second throttle return spring. I noticed you only have one and that could be disastrous.
Re: Had it with the reproduction six-pack idle solenoids [Re: Jeremiah] #606298
02/07/10 12:11 AM
02/07/10 12:11 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
NOS original.
Re: Had it with the reproduction six-pack idle solenoids [Re: Snoopy] #606299
02/07/10 12:12 AM
02/07/10 12:12 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Snoopy are both of those 420's or are they one in the same?
Re: Had it with the reproduction six-pack idle solenoids [Re: ScottSmith_Harms] #606300
02/07/10 12:13 AM
02/07/10 12:13 AM
Snoopy Offline
Snoopy  Offline
One solenoid, two views.
Re: Had it with the reproduction six-pack idle solenoids [Re: Snoopy] #606301
02/07/10 01:14 AM
02/07/10 01:14 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Anybody who wants to get rid of their junk, toasted solenoids, please PM me. Thanks.
Re: Had it with the reproduction six-pack idle solenoids [Re: 6PakBee] #606302
02/07/10 01:36 AM
02/07/10 01:36 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No kidding X 2!
Re: Had it with the reproduction six-pack idle solenoids [Re: ScottSmith_Harms] #606303
02/07/10 02:23 AM
02/07/10 02:23 AM
Snoopy Offline
Snoopy  Offline
Does anyone have any experience with the Standard Brand ES6 idle solenoid? Do they exhibit the same weak action as the newer replacement?
Re: Had it with the reproduction six-pack idle solenoids [Re: Snoopy] #606304
02/07/10 06:45 AM
02/07/10 06:45 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I bet that bolts on and works just fine ...... can I have it?
Re: Had it with the reproduction six-pack idle solenoids [Re: Snoopy] #606305
02/07/10 03:20 PM
02/07/10 03:20 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
I have used that ES6 before it it works fine and is very close to the original, other than the gold bracket.
Re: Had it with the reproduction six-pack idle solenoids [Re: Steve340] #606306
02/07/10 03:36 PM
02/07/10 03:36 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Any of the older OEM style replacment solenoids (such as the Standard example shown above) normally work fine. I have swapped the inner workings of those into older original cases to make them functional again after a replating job when the original internals are corroded or damaged.
Re: Had it with the reproduction six-pack idle solenoids [Re: ScottSmith_Harms] #606307
02/07/10 05:31 PM
02/07/10 05:31 PM
No kidding X 2!
You guys want these POS junk repos too?
