Repo Wire harness vs Original? #604342
02/04/10 10:14 PM
02/04/10 10:14 PM
3
340dart4spd Offline OP
Parts Problem
Parts Problem
3
how are the repop's vs the original.. options please..
Re: Repo Wire harness vs Original? [Re: 340dart4spd ] #604343
02/04/10 10:52 PM
02/04/10 10:52 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Do not know about options, but have an opinion.
The harnesses sold by Year one seem to be pretty close to original, M&H is the supplier from what I recollect.
Bought a hemi engine harness and it is close to the NOS one I have.
My 1.625¢ (adjusted for deflation)
Re: Repo Wire harness vs Original? [Re: sawdust] #604344
02/04/10 11:07 PM
02/04/10 11:07 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Old wire is just that old wire. If all the connectors are good and clean, that is half the battle. Most harnesses have a few toasted wires that need repair. If they are not too bad, they can be fixed. I have repaired many. If the bulkhead and fuse blocks are perfect, then you should be ok with a repair job of the melted wires and really clean the terminal ends. If you are not comfortable with that job, then order the new YO and check to make sure all the wires are correct. I check the wire form continuity and make sure they are in the correct places. I checked my buds new superbird harness and it had a wire in the wrong spot. The wipers would not have worked. The only think I do not like about the 70 B body harness is that they only make one for the 70 Charger with the electric headlight motors. The bird did not use that part of the harness so I removed it and change a wire or two to match the original. If your are buying one for your 70 R/T, It will be the same way.
Re: Repo Wire harness vs Original? [Re: fastmark] #604345
02/04/10 11:11 PM
02/04/10 11:11 PM
3
Parts Problem
Parts Problem
3
I have 1/2 doz used ones.. I will prob go the recon route..was just thinking how much cleaner it would look with new repo wires... thanks and yes it's for a 70 Coronet B-body
Re: Repo Wire harness vs Original? [Re: 340dart4spd ] #604346
02/04/10 11:17 PM
02/04/10 11:17 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Hardens has the correct harness for a 70. Even has a version prewired for mopar electronic ignition. Got one for my 68 looks super fit nice and evey thing worked with no mods needed.
Re: Repo Wire harness vs Original? [Re: Dougsmopars] #604347
02/04/10 11:20 PM
02/04/10 11:20 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Is this the company that sells to YO? I heard they are the best.
Re: Repo Wire harness vs Original? [Re: fastmark] #604348
02/04/10 11:28 PM
02/04/10 11:28 PM
Dougsmopars Offline
Dougsmopars  Offline
Re: Repo Wire harness vs Original? [Re: Dougsmopars] #604349
02/05/10 12:01 AM
02/05/10 12:01 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If you have an NOS harness and it's been stored clean and dry it should be just fine, I've never seen a bad one yet and I've been though many of them. M&H is the best harness reproduction wire source there is but they are usually just close, I haven't seen "Perfect" yet and probably never will due to different materials, connectors, wire color, or just added or lacking connections due them typically being patterned from prints rather than modeled from an actual original example.
If the choice were between used original and new M&H I'd go with new, used 40 year old harnesses are time bombs.
Re: Repo Wire harness vs Original? [Re: ScottSmith_Harms] #604350
02/05/10 12:09 AM
02/05/10 12:09 AM
3
Parts Problem
Parts Problem
3
does this apply to chassis wire harness too..
Re: Repo Wire harness vs Original? [Re: 340dart4spd ] #604351
02/05/10 12:58 AM
02/05/10 12:58 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Chassis? Not sure what you are describing?
Re: Repo Wire harness vs Original? [Re: ScottSmith_Harms] #604352
02/05/10 01:03 AM
02/05/10 01:03 AM
3
Parts Problem
Parts Problem
3
harness running to tail lights...headlights..any body harness other then engine or dash harness
Re: Repo Wire harness vs Original? [Re: 340dart4spd ] #604353
02/05/10 01:07 AM
02/05/10 01:07 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Sure, same opinion applies regardless
Re: Repo Wire harness vs Original? [Re: 340dart4spd ] #604354
02/05/10 01:42 AM
02/05/10 01:42 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
It's one of the few, and I mean few, reproduction parts that fits and functions very well. I have installed countless number of these in all sorts of cars and never a single issue. Even the dash harnesses are great. I have "restored" several sets of original harnesses as well. Lacquer thinner works great to restore the color of the wiring and have the proper harness wrap and most original connectors. With patience, one can get a a nice finished product. But unless you are looking for the ultimate in correctness it's still better, from a functionality standpoint, to have the new stuff. You would be shocked(pun intended) at how much resistance an old set of wires carry.
MB
Re: Repo Wire harness vs Original? [Re: HPMike] #604355
02/05/10 01:02 PM
02/05/10 01:02 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I'm with Mike and Scott (yeah, I know; no big surprise! )
I just installed a new M&H dash harness last weekend in my '70 Coronet and was pretty happy with it. My original harness was GARBAGE and what wasn't painted, melted or spliced was brittle as heck....there was no way I'd want to use the original harness on a full blown resto unless it was just about perfect.
My only complaint was my harness was tagged for a Coronet with rallye dash but it had the extra wires for the Charger headlight doors and faced with taping them off or hacking them off, I chose the latter....which was hard to do on a $600.00 harness....
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Repo Wire harness vs Original? [Re: DPelletier] #604356
02/05/10 03:15 PM
02/05/10 03:15 PM
Long Island NY
yellow sixpack Offline
Long Island NY
My waring harness were all shot. I purchased all new wiring harnesses from M&H. Very happy. If you spend alot of money on your car you dont want it to go up in smoke with an electrical problem because of a 40 year old wiring harness.
If you can't be smart.....don't be stupid!
Re: Repo Wire harness vs Original? [Re: DPelletier] #604357
02/05/10 03:17 PM
02/05/10 03:17 PM
Arizona
az426john Offline
az426john  Offline
Arizona
I bought a new wiring harness from YO for my 67 GTX Hemi car and the oil pressure switch wire was in the wrong location and the tach wire was the wrong color.
I called M&H and they said to just send them my old harness and the new harness and they would make the new one match the old one.
Research revealed that it appears the factory blueprint for the 67 Hemi "B" body Plymouth is incorrect and possibly someone tried to integrate later wiring for an in-dash tach into the 67 Hemi harness.
They were great folks to deal with and they asked if I would pay shiping both ways. This was a small price to pay for the service provided.
Re: Repo Wire harness vs Original? [Re: az426john] #604358
02/05/10 03:23 PM
02/05/10 03:23 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Right, those are the types of things that they get wrong on occasion,the last 67 harness I ordered had the same issues and also had the wrong color (and shape) fusable link wire and molded tab. How does this happen? Simple, the prints callout a blue wire, but the print doesn't say "with a molded yellow fusable link tab" so they made the entire wire and tab blue, the shape of the tab is square vs round as it molds around the wire (as originals were, once again, print doesn't call that out, nor does it call out what shade of blue the wire is, originals were darker than reproductions,etc. As you said, if you offer an original harness to copy they are willing to help which is huge.
Re: Repo Wire harness vs Original? [Re: ScottSmith_Harms] #604359
02/05/10 07:35 PM
02/05/10 07:35 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I guess I should clarify my statement some. I was referring to dash or instrument wiring. Sometimes you can save it. Engine harness is completely different. I always buy new. Rear tail light it the same as a dash harness. Sometimes it is ok.
Re: Repo Wire harness vs Original? [Re: fastmark] #604360
02/05/10 09:26 PM
02/05/10 09:26 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
I can understand your concern, of all the harnesses the most costly is the under dash. One thing that can make a difference in whether to replace is where the car came from a shore are,ie NJ, and/or if it was previously melted or modified. Even if not we have worked on cars (our own at times and for customers too) and they had hard start problems, burned up turn signal switches, etc.
Turned out the main harness had resistance and corrosion in the wires. Even if you clean the terminals there can be oxidation in the wires that creates resistance and causes heat, burned fuses, and melted wires. For the $500-$600 cost of the main harness it is not worth losing your car to fire. Or, having the car die on a trip due to an old harness.
Just for fun you can strip back one of the wires and see if it is green, if it is chances are the whole harness is a disaster waiting to happen.
Re: Repo Wire harness vs Original? [Re: sawdust] #604361
02/05/10 10:03 PM
02/05/10 10:03 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yep!
To add to that the ammeter wires and bulkhead connectors tend to be the biggest problem areas. As far as corrosion, I agree, upon a quick inspection peeling wire covers back at the ends of a harnesses, condition can be spot checked for corrosion, usually turning dark or green as opposed to a nice bright & healthy copper color. But don't stop there, corrosion often starts further up the wire from the ends and remain hidden until it gets hot from resistance and self destructs.
