Re: performer rpm on a 440 fit...
[Re: 70VcodeCoronetRT]
#602558
02/04/10 12:17 AM
02/04/10 12:17 AM
Posts: 849 Avondale AZ
Prodart440
Avondale AZ
I have it with a 1" spacer on my 71 cuda. I had to use a very short air filter with a drop base. Probably choking the crap out of the engine, but it seems to be happy. I don't know if the challenger is the same though.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: gomangoRTSE]
#602564
02/04/10 01:52 PM
02/04/10 01:52 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
So am I to understand that the RPM manifold wont clear a CHallenger Hood (if) I decide to use the factory stock breather?
You cannot run the complete factory air cleaner assembly...so NO. But you can buy a drop base for your lid and it will fit.
[Re: Lew]
#602566
02/04/10 03:07 PM
02/04/10 03:07 PM
Posts: 211 ILL
Greentween
ILL
I'm using 440 in a challenger (R/T hood) with performer rpm manifold and a eddie 800avs, must use drop base air filter and even then you must be careful of the height of the air cleaner stud-nut. And thats with a .25" thick gasket. From what I understand, if you use a performer manifold, or a holley SD the stock one fits.
Height with the eddie 800avs, or a holley DP carb was the same as I had a holley carb before.
Something to consider - vapor lock. With this manifold, there is no room to run a thick gasket to insulate carb from heat. Wish I went with the holley SD manifold instead.
[Re: Greentween]
#602567
02/04/10 03:13 PM
02/04/10 03:13 PM
Mr.Yuck
Brookeville, Md
I'm using 440 with performer rpm, must use drop base air filter and even then you must be careful of the height of the air cleaner stud-nut. From what I understand, if you use a performer manifold, or a holley SD the stock one fits.
yes yes yes...cut your stud SHORT.
