Re: Those with mini tubbed Dusters/Demons, what ....
[Re: ORANGE TWIST71]
#60163
05/20/08 03:15 PM
05/20/08 03:15 PM
Posts: 6,847 Missouri
StrokerPost
Missouri
My Demon has 30x13.5-15 MT Street tires with 15x10 Pro Star wheels with 4 1/2 inch back spacing.I also have a narrowed Dana with ladder bars & coil overs.
Did you alter your wheel openings at all? seems like you would've had to. The way yours looks (color/stripe) is exactly what he described to me as to how he wants to paint it. Feel free to email me some more pix or just post'm here. Thanks.
[Re: dvw]
#60165
05/20/08 06:50 PM
05/20/08 06:50 PM
Posts: 2,523 God's Country Maryland
GODSCOUNTRY340
14' wide x 32" tall. Stock frame but sectioned it. 12" Centerlines with 5 5/16" BS.
[Re: demon440]
#60168
05/20/08 08:02 PM
05/20/08 08:02 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
15x12 with 6" B/S.Leaf springs moved into the frame rail.We are using a 12.2x31.25 tire,obviously we had to trim the wheel openings.As posted,28's are the biggest without a bit of trimming.
Sometime in the future,I will repaint and put the fender openings back to a original apperance,but will be using a 29.5 tire.
[Re: 8secDart]
#60171
05/20/08 09:57 PM
05/20/08 09:57 PM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
My old junk had a stock width axle, springs moved into frame rails, mini tubbed, 15x10 with 6" BS, 29.5x10.5W(pictured). When I bought it, it had 12x30 slicks. The front lower edge of the wheel well was trimmed, but not much. I agree with everyone else, 28" max if you don't cut it.
[Re: Dart1031]
#60172
05/20/08 10:26 PM
05/20/08 10:26 PM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
Factory width dana, mini-tub, 15x10 5 1/2 backspace(i think) 325/50-15 street radials. That is 28 tall. I really want more tire height. I think I might trim the 1/4's after this next pair of tires is gone because in a year or 2 the car is getting a complete makeover and then I will strecth the 1/4's.
[Re: StrokerPost]
#60175
01/21/10 07:32 PM
01/21/10 07:32 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I put 28-10.5 W M/T slicks on my Demon ,I moved the leaf springs in to the frame rails and knocked the stock wheel tub in with a hammer. I painted the inside of the trunk and you can not tell it has been modified. I have 15x10 Holeshot wheels with 6in back spacing. I also did the same thing to my 69 Valiant and put the same tires and wheels on it. They both had stock width A-body 8 3/4 rears with superstock springs.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: viperblue72]
#60176
01/21/10 07:42 PM
01/21/10 07:42 PM
Posts: 316 Freeport, Pa
whiskeyrunner
Freeport, Pa
got any pics? viperblue?
[Re: whiskeyrunner]
#60177
01/21/10 07:59 PM
01/21/10 07:59 PM
johnal
super street
super street
just did one of my demons stock housing and axels.and put a 295 50 15 with 6.5 backspace and lowered the car down and have tons of room car sits down over the tire looks good.tire is 12in wide and 28in tall.
[Re: StrokerPost]
#60178
01/21/10 08:46 PM
01/21/10 08:46 PM
Thumperdart
State of confusion
I use a stock length A body housing and run 15x12 drag stars w/7 1/2" backspacing but I cut the whole wheel well to clear a 30" tire w/room to spare. It`s also mini-tubbed and the springs are moved into the frame rails.
[Re: Thumperdart]
#60179
01/21/10 11:20 PM
01/21/10 11:20 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Virgin sheet metal is a lot easier to work on than rusted stuff is I would (and did) stretch the wheel wells now before you finish the car and paint it. My car has the wheel wells stretched five inches, three inches forward of the original axle centerline and two inches to the rear, I also moved the rear end forward one inch at the same time My car in this picture has 315x60x15 MT ET Street Radails on ten inch rims with 5 3/8 backspacing (it was suppose to be 5.5 backspacing )I also have a set of 10.5x31x15W tires on ten inch rims with the 5.5 backspacing and they fit as well as the M/T radials do and the slicks fill the rear wheelwells up a little better I use ladder bars and coil overs and full size wheel tubs into the stock sub frames EDIT: Oops, forgot to attach the picture Last thing, several years ago I was at Mopar race at Woodburn drag strip here in Oregon, a younger racer came up and stoop down to look at my tires and car, he stood up and said "you can't fit those tires on these cars, I have a 1971 Duster and there is now way I can fit that size tire on my car I let him look at it for a while and finally told him my 1/4 panels are not stock, he gave me a weird look and stoop down again and took another, closer look I fool him and a lot of other Mopar racers and street people Do it now,(sheet metal work) not later
