Re: Those with mini tubbed Dusters/Demons, what ....
[Re: ORANGE TWIST71]
#60163
05/20/08 03:15 PM
05/20/08 03:15 PM
Posts: 6,847 Missouri
StrokerPost
Missouri
My Demon has 30x13.5-15 MT Street tires with 15x10 Pro Star wheels with 4 1/2 inch back spacing.I also have a narrowed Dana with ladder bars & coil overs.
Did you alter your wheel openings at all? seems like you would've had to. The way yours looks (color/stripe) is exactly what he described to me as to how he wants to paint it. Feel free to email me some more pix or just post'm here. Thanks.
[Re: dvw]
#60165
05/20/08 06:50 PM
05/20/08 06:50 PM
Posts: 2,537 God's Country Maryland
GODSCOUNTRY340
14' wide x 32" tall. Stock frame but sectioned it. 12" Centerlines with 5 5/16" BS.
[Re: demon440]
#60168
05/20/08 08:02 PM
05/20/08 08:02 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
15x12 with 6" B/S.Leaf springs moved into the frame rail.We are using a 12.2x31.25 tire,obviously we had to trim the wheel openings.As posted,28's are the biggest without a bit of trimming.
Sometime in the future,I will repaint and put the fender openings back to a original apperance,but will be using a 29.5 tire.
[Re: 8secDart]
#60171
05/20/08 09:57 PM
05/20/08 09:57 PM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
My old junk had a stock width axle, springs moved into frame rails, mini tubbed, 15x10 with 6" BS, 29.5x10.5W(pictured). When I bought it, it had 12x30 slicks. The front lower edge of the wheel well was trimmed, but not much. I agree with everyone else, 28" max if you don't cut it.
[Re: Dart1031]
#60172
05/20/08 10:26 PM
05/20/08 10:26 PM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
Factory width dana, mini-tub, 15x10 5 1/2 backspace(i think) 325/50-15 street radials. That is 28 tall. I really want more tire height. I think I might trim the 1/4's after this next pair of tires is gone because in a year or 2 the car is getting a complete makeover and then I will strecth the 1/4's.
[Re: StrokerPost]
#60175
01/21/10 07:32 PM
01/21/10 07:32 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I put 28-10.5 W M/T slicks on my Demon ,I moved the leaf springs in to the frame rails and knocked the stock wheel tub in with a hammer. I painted the inside of the trunk and you can not tell it has been modified. I have 15x10 Holeshot wheels with 6in back spacing. I also did the same thing to my 69 Valiant and put the same tires and wheels on it. They both had stock width A-body 8 3/4 rears with superstock springs.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: viperblue72]
#60176
01/21/10 07:42 PM
01/21/10 07:42 PM
Posts: 316 Freeport, Pa
whiskeyrunner
Freeport, Pa
got any pics? viperblue?
[Re: whiskeyrunner]
#60177
01/21/10 07:59 PM
01/21/10 07:59 PM
johnal
super street
super street
just did one of my demons stock housing and axels.and put a 295 50 15 with 6.5 backspace and lowered the car down and have tons of room car sits down over the tire looks good.tire is 12in wide and 28in tall.
[Re: StrokerPost]
#60178
01/21/10 08:46 PM
01/21/10 08:46 PM
Thumperdart
State of confusion
I use a stock length A body housing and run 15x12 drag stars w/7 1/2" backspacing but I cut the whole wheel well to clear a 30" tire w/room to spare. It`s also mini-tubbed and the springs are moved into the frame rails.
[Re: Thumperdart]
#60179
01/21/10 11:20 PM
01/21/10 11:20 PM
Posts: 43,307 Bend,OR USA
Cab_Burge
Virgin sheet metal is a lot easier to work on than rusted stuff is ![](/ubbthreads/images/graemlins/scope.gif) I would (and did) stretch the wheel wells now before you finish the car and paint it. ![](/ubbthreads/images/graemlins/Twocents.gif) My car has the wheel wells stretched five inches, three inches forward of the original axle centerline and two inches to the rear, I also moved the rear end forward one inch at the same time ![](/ubbthreads/images/graemlins/thumbs.gif) My car in this picture has 315x60x15 MT ET Street Radails on ten inch rims with 5 3/8 backspacing (it was suppose to be 5.5 backspacing ![](/ubbthreads/images/graemlins/rant.gif) )I also have a set of 10.5x31x15W tires on ten inch rims with the 5.5 backspacing and they fit as well as the M/T radials do and the slicks fill the rear wheelwells up a little better ![](/ubbthreads/images/graemlins/thumbs.gif) I use ladder bars and coil overs and full size wheel tubs into the stock sub frames ![](/ubbthreads/images/graemlins/thumbs.gif) EDIT: Oops, forgot to attach the picture ![](/ubbthreads/images/graemlins/blush.gif) Last thing, several years ago I was at Mopar race at Woodburn drag strip here in Oregon, a younger racer came up and stoop down to look at my tires and car, he stood up and said "you can't fit those tires on these cars, I have a 1971 Duster and there is now way I can fit that size tire on my car ![](/ubbthreads/images/graemlins/confused.gif) I let him look at it for a while and finally told him my 1/4 panels are not stock, he gave me a weird look and stoop down again and took another, closer look ![](/ubbthreads/images/graemlins/shock.gif) I fool him and a lot of other Mopar racers and street people ![](/ubbthreads/images/graemlins/thumbs.gif) Do it now,(sheet metal work) not later ![](/ubbthreads/images/graemlins/Twocents.gif) ![](/ubbthreads/images/graemlins/thumbs.gif)
