Re: 70 B body tach hole [Re: 70gtx440dana] #599046
05/12/10 05:59 PM
05/12/10 05:59 PM
Buffalo, NY U.S.A.
MrNormsTA Offline
MrNormsTA  Offline
Buffalo, NY U.S.A.
When adding a tach on a non tach car, I would always drill a small hole in one of the extra spots on one of the bulk head connectors and pass a wire thru.
I really didn't care about the hole, but figured some purist might not like it down the road, so why do it.
Re: 70 B body tach hole [Re: DPelletier] #599047
05/12/10 06:17 PM
05/12/10 06:17 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
Dave the problem is your car is metric and is in the other side,It's a Canadian Thind..........lol lol lol...I thought you'd get a kick out of it from our past post exchanges......lolololololllool
Russ....it's the big one in the middle....
Re: 70 B body tach hole [Re: MrNormsTA] #599048
05/12/10 06:27 PM
05/12/10 06:27 PM
USA
b54406barrel Offline
USA
Years ago I had a wrecked 69 Charger dash & put the tach/clock in my 6bbl rr as it didn't have either. Once I found out how crappy (this was in the 70's) it was & hard to read, I took it out. Glad I didn't drill that hole!
Re: 70 B body tach hole [Re: 70gtx440dana] #599049
05/12/10 09:11 PM
05/12/10 09:11 PM
Ohio
70BIRD Offline
70BIRD  Offline
Ohio
These wires are for 70 Charger only. They run the headlight motor to open the doors. You will not need them on a RR. New harness must be generic. I would tape up the connector and even possibly tape this entire pigtail to your harness under dash.
I got the harness from Year One a few months ago and it was listed for 1970 Dodge and Plymouth models with oil gauge and I think it was made by M & H. In any event I'll tape up the connector and move on.
Thanks for the response.
Re: 70 B body tach hole [Re: sixbbl69] #599050
05/13/10 12:41 AM
05/13/10 12:41 AM
Mesa, Az
GETX Offline
GETX  Offline
Mesa, Az
tach hole diameter 13/16"
Re: 70 B body tach hole [Re: 6bblgt] #599051
05/13/10 09:32 PM
05/13/10 09:32 PM
old New Jersey
P
papajohn Offline
super street
papajohn  Offline
super street
P
old New Jersey
Here's my February '70 LA built GTX - original tach hole.
Same as my Feb. '70 LA built Road Runner!
Re: 70 B body tach hole [Re: papajohn] #599052
07/06/11 08:06 PM
07/06/11 08:06 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
I believe the tach grommet was feed through the hole punch above the bulkhead connector when the car was equipped with cruise control. I believe the grommet for the cruise utilized the "normal" tach positon.
As you can see on this '69 Charger R/T equipped with cruise, you can vaguely make out the single-lead tach wire harness out of the top position.
Troy
Houston Mopar Connection Club
Re: 70 B body tach hole [Re: hemi68charger] #599053
07/06/11 08:14 PM
07/06/11 08:14 PM
Houston, Tx
Houston, Tx
Also, as was mentioned, '70 Charger headlamp harness would have been passed through the upper hole. The tach wire harness would have come out just like the B-bodies of '68-'69, the driver's side of the bulkhead connector..
Here's a picture of the firewall of my former '70 six pack Charger R/T without the tach option. The headlamp harness grommet came out above the bulkhead connector..
Troy
Re: 70 B body tach hole [Re: hemi68charger] #599054
07/06/11 08:15 PM
07/06/11 08:15 PM
Kelowna, B.C. Canada
DPelletier Offline OP
Could be; I thought it might be a Charger thing.....
In any case I'm 99% sure that a non-cruise Superbee should have it in the lower spot across from the wiring block.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 70 B body tach hole [Re: DPelletier] #599055
07/06/11 08:41 PM
07/06/11 08:41 PM
Houston, Tx
Houston, Tx
Dave,
If you're referring to the position between the bulkhead connector and the booster/master-cylinder like in papajohn's picture above, you are correct.......
Troy
Troy
Re: 70 B body tach hole [Re: 70gtx440dana] #1817673
05/03/15 01:35 PM
05/03/15 01:35 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Originally Posted By 70gtx440dana
Here is a picture....not sure on the size!
That's about where my tach wire comes out on my GTS
Abe Lincoln
