Copper Spray or HighTack - Shim Head Gasket? #595996
01/27/10 08:54 PM
01/27/10 08:54 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline OP
VanishPt  Offline OP
V
Felpro 1145 Steel Shim head gasket. I die grinded the pushrod holes a little larger in the gasket. The metal dust stuck to the thin film on the gasket , so i had to clean the gaskets down to bear metal.
I plan on putting the Right Stuff around the water and oil passages. Should I spray the entire gasket with either Copper or High Tack? Which one would you reccomend? Do I need to be concerned about getting any on the fire ring area?
Re: Copper Spray or HighTack - Shim Head Gasket? [Re: VanishPt] #595997
01/27/10 09:23 PM
01/27/10 09:23 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Are you using iron or aluminum heads???
I use the copper spray for iron heads, but use the high temp aluminum ceramic rattle can for aluminum heads.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Copper Spray or HighTack - Shim Head Gasket? [Re: VanishPt] #595998
01/27/10 09:31 PM
01/27/10 09:31 PM
All metal steel shim gasket? (1)Copper (2) even coat all over including the fire ring.
Re: Copper Spray or HighTack - Shim Head Gasket? [Re: RapidRobert] #595999
01/27/10 09:33 PM
01/27/10 09:33 PM
V
VanishPt Offline OP
VanishPt  Offline OP
V
these are al heads and an iron block
Re: Copper Spray or HighTack - Shim Head Gasket? [Re: 68LAR] #596000
01/27/10 09:34 PM
01/27/10 09:34 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
...Permatex Gold works great on Iron, I've done the silver/alumimun spraybomb on Iron heads as well, great results,....Copper is tougher to pull a head later on though
Re: Copper Spray or HighTack - Shim Head Gasket? [Re: VanishPt] #596001
01/27/10 09:37 PM
01/27/10 09:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Go with the Silver/Aluminum ceramic header paint, spray the gasket fully both sides, install wet, no need to spray the block deck, or head, just the gaskets sides, have everything ready, torque to spec
