Automatic shifters? #594279
01/26/10 10:17 AM
01/26/10 10:17 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Anyone have a favorite brand or style of aftermarket shifter and why? I am needing one for my 57 truck project and am looking for ideas. Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Automatic shifters? [Re: rattler] #594280
01/26/10 06:15 PM
01/26/10 06:15 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
I used Lokar on the 36. Have a 518 trans. Seem to have good adaptability to unique situations.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Automatic shifters? [Re: rattler] #594281
01/26/10 07:31 PM
01/26/10 07:31 PM
Florida STAYcation
BeEtLeJuIcE ! Online penguin-006
The village idiot's idiot
BeEtLeJuIcE !  Online Penguin-006
Florida STAYcation
I really REALLY like a pushbutton shifter.... I am putting one into a dragster and a motorhome and would FURR-SURE put one into a street-rod .. 'effen I had one.
Re: Automatic shifters? [Re: 36PLYM] #594282
01/26/10 11:23 PM
01/26/10 11:23 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
I may end up modifying one to look like a standard shift, not sure yet. One problem with the normal aftermarket shifters is thier height. It will need to be tall enough for a truck. Randy
Re: Automatic shifters? [Re: rattler] #594283
01/29/10 04:47 PM
01/29/10 04:47 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
i have a lokrap in my rod,,in my experience it doesnt seem to adapt well to a 904,,as far as the built in nutrel safty switch,,it doesnt work properly in all positions,,but they do have several length arms to choose from,,,gennie shifters were first lokrap stole there gate design and added a button to the shifter,,,,
i also wanted to put a push button in my rod,,but the cost to adapt a push button tranny to except a modern lock up converter wasnt worth it in my eyes,,,imperial services makes a push button adapter for non push buton trannys,, but ive \heard its expensive,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Automatic shifters? [Re: rattler] #594284
01/29/10 04:47 PM
01/29/10 04:47 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
Then definitely get the Lokar.
Had a Gennie in my Trailduster, and loved it. The Lokar has a pushbutton that my Gennie didn't.
Whenever I am online I am totally naked. (Under my clothes)
Re: Automatic shifters? [Re: Cooter] #594285
01/29/10 08:27 PM
01/29/10 08:27 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
I have a catalog on the way from Gennie. I liked the looks of stuff on thier web site and didn't want a button on the shifter.Randy
Re: Automatic shifters? [Re: rattler] #594286
01/31/10 02:13 AM
01/31/10 02:13 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
I have a catalog on the way from Gennie. I liked the looks of stuff on thier web site and didn't want a button on the shifter.Randy [
/quote]
gennie has no button,,but you have to kick the arm from side to side from gate to gate,,nice shifter a buddy has one in a 37 ply with a 413/727
they ofer a wider selection of arms now,,,
2015 cherokee
2013 R/T classic
Re: Automatic shifters? [Re: rattler] #594287
03/07/10 10:51 PM
03/07/10 10:51 PM
scratchnfotraction Offline
yep,i am looking at the comander shifter myself and just got the top hat skull air clear hold down
very cool
lot of handles to choise from also
the floor mount lokar gets a looky see also as i might not have the clearance on top of the tranz for the shifter to mount correctly
Re: Automatic shifters? [Re: scratchnfotraction] #594288
03/16/10 10:01 PM
03/16/10 10:01 PM
Iowa,US
4bbl Offline
4bbl  Offline
Iowa,US
I am using the column out of the 85 150 on the 50 rod, including column shifter. had to shorten it three or four times to retain all switches and shifter. Not fun but time was cheep, after market parts were not.
4bbl If you can't hear it coming what's the point.......
Re: Automatic shifters? [Re: 4bbl] #594289
03/16/10 11:03 PM
03/16/10 11:03 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
kool man,,modifing is hot rodding,,,we dont always have to buy it,,,nothing wrong with making it,,,,,,pics please
2015 cherokee
2013 R/T classic
Re: Automatic shifters? [Re: fstfish66] #594290
03/17/10 08:29 AM
03/17/10 08:29 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
I ended up using an old Hurst ratchet shifter from a swap meet. I cut the handle off short and bolted on an old 3-speed shifter handle. Except for being a long-throw between gears it seems to work pretty good and has the look i wanted. I also used an old b-body console lid and built lower sides for it to form a custom console out of 18ga. steel. It is funny what you can do with more time than money. Randy
Re: Automatic shifters? [Re: rattler] #594291
03/17/10 11:20 PM
03/17/10 11:20 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
building and custom one off is kool,,,,the throw just seems longer,,because you made the handle longer,,,,grab it as low as you can and shift it,,you will see that the throw seems shorter,,,,pics please
2015 cherokee
2013 R/T classic
Re: Automatic shifters? [Re: fstfish66] #594292
03/19/10 04:01 PM
03/19/10 04:01 PM
Re: Automatic shifters? [Re: scratchnfotraction] #594293
03/19/10 07:11 PM
03/19/10 07:11 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
I'll try to take a pic of my shifter and get it posted. I spent the afternoon rescueing a 440 from a 78 motorhome. What a pain in the a** pulling that motor. It had a trany with it, but i had never seen a 727 with a bolt on yoke and short tailhousing like it had.
Re: Automatic shifters? [Re: scratchnfotraction] #594294
03/21/10 11:47 PM
03/21/10 11:47 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
loks like an engine pic,,n ot a shifter and console,,,lol
2015 cherokee
2013 R/T classic
Re: Automatic shifters? [Re: rattler] #594295
03/21/10 11:49 PM
03/21/10 11:49 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
bolt on yoke ?? you meen like a trunion ?? 4 bolt flange??? some of those motor homes had 413,s in them,,,may just be a 413 and a vintage pre slip yoke tranny,,
2015 cherokee
2013 R/T classic
Re: Automatic shifters? [Re: fstfish66] #594296
03/22/10 09:23 AM
03/22/10 09:23 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
No, the tail housing on this trany was set up for a two piece slider driveshaft like a 4-wheel drive use's.The forward u-joint bolted to the trany with straps the same as the rear.
Re: Automatic shifters? [Re: rattler] #594297
03/22/10 09:44 PM
03/22/10 09:44 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Here are some pics, i hope.
Re: Automatic shifters? [Re: rattler] #594298
03/22/10 09:49 PM
03/22/10 09:49 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Shifter pics
