Bearing surface and detonation question #593861
01/25/10 07:38 PM
01/25/10 07:38 PM
Cookeville
Chilort Offline OP
Will Work For Mopars
Chilort  Offline OP
Cookeville
I've heard that the bearing surface on an engine that has been experiencing serious detonation will look different than just a worn out bearing.
Any pictures?
Re: Bearing surface and detonation question [Re: Chilort] #593862
01/25/10 08:23 PM
01/25/10 08:23 PM
tx
craigsmytcudas Offline
tx
First look at a berring chart from any major brand good info , I find that cars with berring hammer will have what looks like rail road tracking on the back side .This can be seen on a berring thats been destroyed even an engine thats seen hydrolic and or methonal dumping . also some call it ruffles have ridges like the tater chips .c
Re: Bearing surface and detonation question [Re: Chilort] #593863
01/25/10 08:54 PM
01/25/10 08:54 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Any pictures?
The tops of the pistons often look like someone was beating on them with a ball peen hammer as well.
Re: Bearing surface and detonation question [Re: Lefty] #593864
01/25/10 11:10 PM
01/25/10 11:10 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I was under the impression that the bearing surface looked something like this.
Re: Bearing surface and detonation question [Re: Chilort] #593865
01/25/10 11:49 PM
01/25/10 11:49 PM
tx
tx
Flip it over and show a pic .c
Re: Bearing surface and detonation question [Re: craigsmytcudas] #593866
01/25/10 11:58 PM
01/25/10 11:58 PM
tx
tx
The pic looks like its stacking all the way around like its running hot or oil starving .
old school builders clearenced engines and used heavy oil and stacking berrings would look like the one you posted . If hammered it would bronze in the center and also egg the rod after a while .c
