99 ram wont idle when first started #591553
01/23/10 04:27 PM
01/23/10 04:27 PM
central pa
darted1 Offline OP
darted1  Offline OP
central pa
I have a 99 ram 2500 360 auto this morning battery was all but dead it turned over once or twice then nothing. put it on the charger then started it but unless you hold your foot on the gas and keep it idling it stalls. when driving it is ok but shut it off for a little while and same thing ,idles ok when driving at red lights. just when first started cold or after setting a couple of minutes it will stall. any ideas or questions thanks ed
ED M
Re: 99 ram wont idle when first started [Re: darted1] #591554
01/23/10 04:31 PM
01/23/10 04:31 PM
Pa, USA
65barracuda_S Offline
super street
super street
Pa, USA
You need to replace the battery!! The controller ECM goes crazy with a poorly charged/shorted battery.
Re: 99 ram wont idle when first started [Re: 65barracuda_S] #591555
01/23/10 04:42 PM
01/23/10 04:42 PM
central pa
darted1 Offline OP
darted1  Offline OP
central pa
thanks i wasn't sure if that would cause that or not thanks again ed
ED M
Re: 99 ram wont idle when first started [Re: darted1] #591556
01/23/10 06:13 PM
01/23/10 06:13 PM
Andrewh Offline
Andrewh  Offline
if that doesnt fix it, clean out the iac.
Re: 99 ram wont idle when first started [Re: Andrewh] #591557
01/24/10 11:26 AM
01/24/10 11:26 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
sounds like it!!!!!!!!!!! stuck closed when cold!!!!
